[rebel-builders] EliteProp&airfilter
John W
Post by John W » Sun Feb 19, 2012 7:00 pm
Vans Group Buy on Icom 210 closes the 12th Oct
1058.oo is the estimate.
go to Vans Airforce the forum under Icom 210
here are the links .
http://www.vansairforce.com/community/s ... hp?t=21312
http://www.vansairforce.com/community/s ... hp?t=17563
--- Walter Klatt <Walter.Klatt@shaw.ca> wrote:
Yeah, I will have to go through all that cowl and
cooling stuff one more
time. I know you guys out east like the metal cowls.
Despite the pain to get
the fiberglass one off and on, I still prefer the
looks.
I think you get better cooling too on the metal
cowls because your inlets
are bigger. If you recall, that is what finally
fixed mine, and I didn't
have to change them much either. But that resulted
in 50 degrees cooler.
But in any case, where do you get this fiberglass
plenum? Will it fit the
speed cowl?
I did find the part number for the carb heat box.
Van's calls it an airbox,
which is why I missed it initially.
I will also be installing a new radio. Any
recommendations? I want one that
has a high power transmit, and will not give me any
grief with noise, either
antenna RF or from the electrics. I am pretty happy
with the rest of my
instruments. With my new LS EI, I will also have a
display that shows the
engine map and timing advance, which should be
interesting. It even has the
option of a knob to adjust your timing advance, but
I don't think I will
push my luck with that one.
Another question for the XP360. Is the carb offset
to the pilot side, and is
there a special speed cowl option from Murphy for
this? My engine is an A4M.
[mailto:mike.davis@dcsol.com] On Behalf Of Bob
Patterson
Sent: Wednesday, October 10, 2007 6:53 PM
Subject: Re: [rebel-builders] EliteProp&airfilter
Hi John ! (and Walter ...) ;-)
Ralph Baker has aready been through this whole
exercise
with his Elite - emails are in the archives. You
can search
by SENDER ...and... KEYWORD in the BODY ...
He used the Vans airbox & baffles (it's a big
round filter !)
and a Vans 'snorkel' fitting glassed onto the bottom
front of the
'speed cowl' - a very nice looking installation. He
wanted
foolproof alternate air, which the Vans setup gives
by a spring-loaded door .... plus the large paper
filter.
Ralph must be travelling, or he'd have chimed in
maybe we can get him to post a few pics to the FILES
section ...
BTW Walter - Pierre used the molded fiberglass
plenum for his
XP - it ducts ALL of the air in and down through the
cylinders.
Absolutely NO cooling problems ! Only disadvantage
is -
you have to take it off to get at the spark plugs
Of course, he did have a great 4 door metal cowling
with
a large exit chute at the bottom.... (and the Thorp
T-18
nosebowl - $80 from Aircraft Spruce ...)
http://www.prosumers.ca
On Thursday 11 October 2007 00:48, John W wrote:
Tks Bob will be interested to know .
Ive started throwing stuff out to lighten up
already.
Big difference between 2050 and 2200 in
performance.
Put a new element in the Bracket today gotta
figure
out how to open it up without wrecking the
cowling.
--- Robert Andrews <robert@montanasky.us> wrote:
John,
Just measured the Bracket BA-4106 filter ... 5"
x
5.5" or 27.5 sq.in. But
this isn't the sq in of exposed filter ... its
outside dimensions of the
filter which includes the metal frame. The
dimensions for the exposed
filter at the front are 3.75" x 4.25" or only
15.9
sq. in. ... a tad bit
short of the 27 sq. in. Sean mentions as the min
required. Wonder if 612e
needs a filter "mod" also. Looking forward to
doing
the mentioned run-up
test with and again without the filter.
John - don't know what 612e weighs. A lot of
work's
been done since it last
flew ... to include the amphib hydraulics. I'll
be
weighing it soon ...
will let you know.
Bob 612e
John W
Sent: Wednesday, October 10, 2007 5:05 PM
EliteProp&airfilter
Thanks Sean, Clear to me waht the problem is.
I have noted my carb heat control is making
metal
,ready to fail no doubt. How do I get more air
in
there
without a major mod?
Tks
--- kitplane_solutions@dcsol.com wrote:
airbox
name of
minimum
it
from
Elite
power
easy)
now
=== message truncated ===
____________________________________________________________________________________
Need a vacation? Get great deals
to amazing places on Yahoo! Travel.
http://travel.yahoo.com/
Post by Walter Klatt » Sun Feb 19, 2012 7:00 pm
So these are fiberglass spinners? Are the blade cut-outs done?
Sent: Wednesday, October 10, 2007 8:35 PM
Subject: RE: [rebel-builders] EliteProp&airfilter
The vans bulkheads are prepunched for the prop bolts but you need to put
the dome attach scerws in this is easy beause you can see right through the
fiberglass spinner to drill the holes
Sean
10/10/2007 5:26 PM, walter.klatt@shaw.ca wrote to rebel-builders:
-> Do the Vans spinners come all cut out and holes drilled for prop bolts?
My
-> last one I did from scratch with the Murphy kit, and it was a lot of
work. I
-> was happy with the final result, but like I said, I am getting real lazy
now
-> the second time around, and just want to get it back in the air ASAP.
-> Walter
-> -----Original Message-----
-> From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf
Of
-> kitplane_solutions@dcsol.com
-> Sent: Wednesday, October 10, 2007 8:24 PM
-> Subject: RE: [rebel-builders] EliteProp&airfilter
-> Hi Walter
-> The Vans airbox for the 360 carb or up draft fuel injection will work. It
-> needs
-> a little trim and a bit of glass work but will fit the Murphy cowl I've
done
-> three of them now and they seem to hang together just fine. I also use
Vans
-> tThrottle bracket and spinners they are really nice and are a very good
-> price
-> also. I joke that all of the planes that I build have a Van-Murphy fire
wall
-> forward package
-> Sean
-> On 10/10/2007 4:02 PM, walter.klatt@shaw.ca wrote to rebel-builders:
-> -> You mention Van's air filters. Does Van's sell a carb heat box for the
-> 360
-> -> that would fit the Murphy cowl and what would the part number be? I
-> have
-> -> their catalogue, but couldn't find that item.
-> -> Also I am thinking of taking the lazy route and buying Van's baffles,
-> too.
-> -> The ones for the RV 6, 7, et al are part number BAF-6-360. Are these
-> -> right ones?
-> -> Also, where is the best place to get a good stainless steel exhaust
for
-> the
-> -> 360? I assume it is probably the same as for the 320?
-> -> Walter
-> -> -----Original Message-----
-> -> From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On
Behalf
-> Of
-> -> kitplane_solutions@dcsol.com
-> -> Sent: Wednesday, October 10, 2007 2:20 PM
-> -> To: rebel-builders@dcsol.com
-> -> Subject: [rebel-builders] EliteProp&airfilter
-> -> All Elite kits have been delivered with an airbox that fits an 360
carb
-> but
-> -> the
-> -> airfilter is to small. I can't remeber the name of the person that I
-> spoke
-> -> to at
-> -> Bracket but I was told that an 0-360 needs a minimum of 27 square
-> inchs of
-> -> filter surface. If the supplied airbox is used it will fail in about
25
-> -> hours of
-> -> use this is do to the carb heat door vibrating from the engine trying
-> -> draw
-> -> air from the back side of the door. The first Elite I built for Bob
Fry
-> had
-> -> the
-> -> standard filter and ran like crap at full power while belching black
-> smoke.
-> -> Pulling the filter resulted in almost 200 RPM increase at full
throttle.
-> I
-> -> modified the box for a larger filter (not easy) now I just put Vans
air
-> -> filters
-> -> on and get it over with. Bob's plane is running a 76-56 prop and
pulled
-> 2460
-> -> static at an OAT of about 90 this past summer. Bob cruises at 103 kts.
at
-> -> 2480. This is an XP-360 with one Lightspeed. And it is still for sale
-> take
-> -> advantage of the Canuck Buck and buy it today
-> -> Sean White
-> -> List archives located at: https://mail.dcsol.com/login
-> -> username "rebel" password "builder"
-> -> Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> -> List administrator: mike.davis@dcsol.com
kitplane_solutions
Post by kitplane_solutions » Sun Feb 19, 2012 7:00 pm
No you must cut out the blade openings to many differents blades for one
cut out
Sean
On 10/11/2007 4:39 AM, walter.klatt@shaw.ca wrote to rebel-builders:
-> So these are fiberglass spinners? Are the blade cut-outs done?
-> Walter
Of
-> Sent: Wednesday, October 10, 2007 8:35 PM
-> The vans bulkheads are prepunched for the prop bolts but you need to
put
-> the dome attach scerws in this is easy beause you can see right through
-> fiberglass spinner to drill the holes
-> Sean
-> 10/10/2007 5:26 PM, walter.klatt@shaw.ca wrote to rebel-builders:
-> -> Do the Vans spinners come all cut out and holes drilled for prop bolts?
-> My
-> -> last one I did from scratch with the Murphy kit, and it was a lot of
-> work. I
-> -> was happy with the final result, but like I said, I am getting real lazy
-> now
-> -> the second time around, and just want to get it back in the air ASAP.
-> -> Walter
Behalf
-> Of
-> -> Sent: Wednesday, October 10, 2007 8:24 PM
-> -> Subject: RE: [rebel-builders] EliteProp&airfilter
-> -> Hi Walter
-> -> The Vans airbox for the 360 carb or up draft fuel injection will work. It
-> -> needs
-> -> a little trim and a bit of glass work but will fit the Murphy cowl I've
-> done
-> -> three of them now and they seem to hang together just fine. I also
use
-> Vans
-> -> tThrottle bracket and spinners they are really nice and are a very good
-> -> price
-> -> also. I joke that all of the planes that I build have a Van-Murphy fire
-> wall
-> -> forward package
-> -> Sean
-> -> On 10/10/2007 4:02 PM, walter.klatt@shaw.ca wrote to rebel-builders:
-> -> -> You mention Van's air filters. Does Van's sell a carb heat box for the
-> -> 360
-> -> -> that would fit the Murphy cowl and what would the part number
be? I
-> -> have
-> -> -> their catalogue, but couldn't find that item.
-> -> -> Also I am thinking of taking the lazy route and buying Van's
baffles,
-> -> too.
-> -> -> The ones for the RV 6, 7, et al are part number BAF-6-360. Are
these
-> the
-> -> -> right ones?
-> -> -> Also, where is the best place to get a good stainless steel exhaust
-> for
-> -> the
-> -> -> 360? I assume it is probably the same as for the 320?
-> -> -> Walter
-> -> -> -----Original Message-----
-> -> -> From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On
-> Behalf
-> -> Of
-> -> -> kitplane_solutions@dcsol.com
-> -> -> Sent: Wednesday, October 10, 2007 2:20 PM
-> -> -> To: rebel-builders@dcsol.com
-> -> -> Subject: [rebel-builders] EliteProp&airfilter
-> -> -> All Elite kits have been delivered with an airbox that fits an 360
-> carb
-> -> but
-> -> -> the
-> -> -> airfilter is to small. I can't remeber the name of the person that I
-> -> spoke
-> -> -> to at
-> -> -> Bracket but I was told that an 0-360 needs a minimum of 27
square
-> -> inchs of
-> -> -> filter surface. If the supplied airbox is used it will fail in about
-> 25
-> -> -> hours of
-> -> -> use this is do to the carb heat door vibrating from the engine trying
-> to
-> -> -> draw
-> -> -> air from the back side of the door. The first Elite I built for Bob
-> Fry
-> -> had
-> -> -> the
-> -> -> standard filter and ran like crap at full power while belching black
-> -> smoke.
-> -> -> Pulling the filter resulted in almost 200 RPM increase at full
-> throttle.
-> -> I
-> -> -> modified the box for a larger filter (not easy) now I just put Vans
-> air
-> -> -> filters
-> -> -> on and get it over with. Bob's plane is running a 76-56 prop and
-> pulled
-> -> 2460
-> -> -> static at an OAT of about 90 this past summer. Bob cruises at 103
kts.
-> at
-> -> -> 2480. This is an XP-360 with one Lightspeed. And it is still for sale
-> -> take
-> -> -> advantage of the Canuck Buck and buy it today
-> -> -> Sean White
-> -> -> List archives located at: https://mail.dcsol.com/login
-> -> -> username "rebel" password "builder"
-> -> -> Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> -> -> List administrator: mike.davis@dcsol.com
Post by robert@montanasky.us » Sun Feb 19, 2012 7:00 pm
Sean,
The VAN's website shows a few air boxes for O-360's. Which one did you
use? ... and was there any issues in rigging up carb heat?
Bob 612e
Original Message:
Date: Thu, 11 Oct 2007 12:32:23 -0900
cut out
Sean
-> Walter
Of
put
-> Sean
bolts?
-> My
-> work. I
lazy
-> now
-> -> Walter
Behalf
-> Of
-> -> Hi Walter
work. It
-> -> needs
I've
-> done
use
-> Vans
good
-> -> price
fire
-> wall
-> -> Sean
-> -> 360
be? I
-> -> have
baffles,
-> -> too.
these
-> the
-> for
-> -> the
-> -> -> Walter
-> Behalf
-> -> Of
-> carb
-> -> but
-> -> -> the
-> -> spoke
-> -> -> to at
square
-> -> inchs of
about
-> 25
-> -> -> hours of
trying
-> to
-> -> -> draw
-> Fry
-> -> had
-> -> -> the
black
-> -> smoke.
-> throttle.
-> -> I
-> air
-> -> -> filters
-> pulled
-> -> 2460
kts.
-> at
sale
-> -> take
-> -> -> Sean White
mail2web.com - Microsoft
I checked into this and ended up talking to Tom Glaze at ACS. They needed
500 orders to get that 1058 price, but unfortunately they have only about
100 right now, and likely won't make it to 200 by tomorrow.
While this radio has some nice features, I noticed that it only has 5 watt
transmit output. I thought most had 7 and some have 10.
Some of the places I fly in the mountains here, I am often out of range with
transmit. I can hear a long ways, but can't talk to them.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of John W
Sent: Thursday, October 11, 2007 5:51 AM
looks.
speed cowl?
with the rest of my
Patterson
exercise
can search
round filter !)
front of the
wanted
filter.
section ...
plenum for his
cylinders.
is -
with
T-18
already.
performance.
figure
cowling.
John,
x
15.9
doing
work's
be
will let you know.
Bob 612e
John W
EliteProp&airfilter
metal
in
there
Tks
airbox
name of
minimum
it
from
Elite
power
easy)
now
________
kitplane_solutions
Vans P/N FAB-360/540 fits all 0-360 with a carb
Sean
On 10/11/2007 12:42 PM, robert@montanasky.us wrote to rebel-builders:
-> Sean,
-> The VAN's website shows a few air boxes for O-360's. Which one did you
-> use? ... and was there any issues in rigging up carb heat?
-> Bob 612e
-> Original Message:
-> From: kitplane_solutionsol.com
-> Date: Thu, 11 Oct 2007 12:32:23 -0900
-> No you must cut out the blade openings to many differents blades for one
-> cut out
-> Sean
-> On 10/11/2007 4:39 AM, walter.klatt@shaw.ca wrote to rebel-builders:
-> -> So these are fiberglass spinners? Are the blade cut-outs done?
-> -> Walter
Behalf
-> Of
-> -> Sent: Wednesday, October 10, 2007 8:35 PM
-> -> The vans bulkheads are prepunched for the prop bolts but you need to
-> put
-> -> the dome attach scerws in this is easy beause you can see right
through
-> the
-> -> fiberglass spinner to drill the holes
-> -> Sean
-> -> 10/10/2007 5:26 PM, walter.klatt@shaw.ca wrote to rebel-builders:
-> -> -> Do the Vans spinners come all cut out and holes drilled for prop
-> bolts?
-> -> My
-> -> -> last one I did from scratch with the Murphy kit, and it was a lot of
-> -> work. I
-> -> -> was happy with the final result, but like I said, I am getting real
-> lazy
-> -> now
-> -> -> the second time around, and just want to get it back in the air
ASAP.
-> -> -> Walter
-> Behalf
-> -> Of
-> -> -> Sent: Wednesday, October 10, 2007 8:24 PM
-> -> -> Subject: RE: [rebel-builders] EliteProp&airfilter
-> -> -> Hi Walter
-> -> -> The Vans airbox for the 360 carb or up draft fuel injection will
-> work. It
-> -> -> needs
-> -> -> a little trim and a bit of glass work but will fit the Murphy cowl
-> I've
-> -> done
-> -> -> three of them now and they seem to hang together just fine. I also
-> use
-> -> Vans
-> -> -> tThrottle bracket and spinners they are really nice and are a very
-> good
-> -> -> price
-> -> -> also. I joke that all of the planes that I build have a Van-Murphy
-> fire
-> -> wall
-> -> -> forward package
-> -> -> Sean
-> -> -> On 10/10/2007 4:02 PM, walter.klatt@shaw.ca wrote to rebel-
builders:
-> -> -> -> You mention Van's air filters. Does Van's sell a carb heat box for
-> the
-> -> -> 360
-> -> -> -> that would fit the Murphy cowl and what would the part number
-> be? I
-> -> -> have
-> -> -> -> their catalogue, but couldn't find that item.
-> -> -> -> Also I am thinking of taking the lazy route and buying Van's
-> baffles,
-> -> -> too.
-> -> -> -> The ones for the RV 6, 7, et al are part number BAF-6-360. Are
-> these
-> -> the
-> -> -> -> right ones?
-> -> -> -> Also, where is the best place to get a good stainless steel
exhaust
-> -> for
-> -> -> the
-> -> -> -> 360? I assume it is probably the same as for the 320?
-> -> -> -> Walter
-> -> -> -> -----Original Message-----
-> -> -> -> From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]
On
-> -> Behalf
-> -> -> Of
-> -> -> -> kitplane_solutions@dcsol.com
-> -> -> -> Sent: Wednesday, October 10, 2007 2:20 PM
-> -> -> -> To: rebel-builders@dcsol.com
-> -> -> -> Subject: [rebel-builders] EliteProp&airfilter
-> -> -> -> All Elite kits have been delivered with an airbox that fits an 360
-> -> carb
-> -> -> but
-> -> -> -> the
-> -> -> -> airfilter is to small. I can't remeber the name of the person that
-> I
-> -> -> spoke
-> -> -> -> to at
-> -> -> -> Bracket but I was told that an 0-360 needs a minimum of 27
-> square
-> -> -> inchs of
-> -> -> -> filter surface. If the supplied airbox is used it will fail in
-> about
-> -> 25
-> -> -> -> hours of
-> -> -> -> use this is do to the carb heat door vibrating from the engine
-> trying
-> -> to
-> -> -> -> draw
-> -> -> -> air from the back side of the door. The first Elite I built for Bob
-> -> Fry
-> -> -> had
-> -> -> -> the
-> -> -> -> standard filter and ran like crap at full power while belching
-> black
-> -> -> smoke.
-> -> -> -> Pulling the filter resulted in almost 200 RPM increase at full
-> -> throttle.
-> -> -> I
-> -> -> -> modified the box for a larger filter (not easy) now I just put
Vans
-> -> air
-> -> -> -> filters
-> -> -> -> on and get it over with. Bob's plane is running a 76-56 prop
-> -> pulled
-> -> -> 2460
-> -> -> -> static at an OAT of about 90 this past summer. Bob cruises at
103
-> kts.
-> -> at
-> -> -> -> 2480. This is an XP-360 with one Lightspeed. And it is still for
-> sale
-> -> -> take
-> -> -> -> advantage of the Canuck Buck and buy it today
-> -> -> -> Sean White
-> -> -> -> List archives located at: https://mail.dcsol.com/login
-> -> -> -> username "rebel" password "builder"
-> -> -> -> Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> -> -> -> List administrator: mike.davis@dcsol.com
-> mail2web.com - Microsoft
kitplane_solutions
Post by kitplane_solutions » Sun Feb 19, 2012 7:01 pm
No that is a the original two piece Elite cowl that had a lot of rework done
around the air box. I have since figured out how to put the airbox in without
an extra 50 hours of glass work but it sure looked cool
Sean
On 10/12/2007 4:22 PM, robert@montanasky.us wrote to rebel-builders:
-> Just curious, are this pics of a rebel cowl modified to work with a VANS air
-> box?
-> www.aacnet.com/elite/cowl-1.jpg
-> www.aacnet.com/elite/cowl-3.jpg
-> Bob 612e
-> From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]On Behalf Of
-> WALTER KLATT
-> Sent: Friday, October 12, 2007 2:37 PM
-> Subject: Re: RE: [rebel-builders] EliteProp&airfilter
-> Yes, they are. Email me offline if you want to sell it.
-> Walter
-> From: Robert Johnson <bestofbo@cogeco.ca>
-> Date: Friday, October 12, 2007 2:01 pm
-> > Hi Walter: I have a dynafocal mount for an O320 - are they the
-> > same?? Bob J
-> > ----- Original Message -----
-> > From: "WALTER KLATT" <Walter.Klatt@shaw.ca>
-> > To: <rebel-builders@dcsol.com>
-> > Sent: Friday, October 12, 2007 4:37 PM
-> > Subject: Re: RE: [rebel-builders] EliteProp&airfilter
-> > > Sounds very good.
-> > > Now I also need a new speed cowl and a dynafocal mount. Anyone
-> > have one of
-> > > these they don't need?
-> > > Walter
-> > > ----- Original Message -----
-> > > From: kitplane_solutions@dcsol.com
-> > > Date: Friday, October 12, 2007 12:57 pm
-> > > Subject: RE: [rebel-builders] EliteProp&airfilter
-> > > To: rebel-builders@dcsol.com
-> > >> It does come with all the bits to assemble the door but you will
-> > >> need a 2"
-> > >> flange to attach the scat hose to your heat muff. Vans also
-> > >> includes a
-> > >> alternate air door kit to bypass the filter as the normal setup
-> > >> filters both
-> > >> warm and cold air. The original bypass door was held close by a
-> > >> magnet and
-> > >> was to open itself if the filter plugged but was found to open
-> > >> when ever it
-> > >> felt like it. They now have a cable operated door in its place.
-> > >> You do not have
-> > >> to install this door if you are not flying in heavy snow or
-> > >> freezing rain as it is
-> > >> olny there in case you pack the air filter full of ice and snow
-> > >> important if you
-> > >> fly a lot of IFR. If you are ever in dought just pull the carb
-> > >> heat on as it is
-> > >> also filtered you can even use it on the ground.
-> > >> Sean
-> > >> On 10/12/2007 10:18 AM, walter.klatt@shaw.ca wrote to rebel-
-> > builders:>>
-> > >> -> Does it come with the carb heat gate or is this separate?
-> > >> -> Walter
-> > >> -> -----Original Message-----
-> > >> -> From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On
-> > >> Behalf
-> > >> Of
-> > >> -> kitplane_solutions@dcsol.com
-> > >> -> Sent: Thursday, October 11, 2007 7:29 PM
-> > >> -> To: rebel-builders@dcsol.com
-> > >> -> Subject: RE: [rebel-builders] EliteProp&airfilter
-> > >> -> Vans P/N FAB-360/540 fits all 0-360 with a carb
-> > >> -> Sean
-> > >> -> On 10/11/2007 12:42 PM, robert@montanasky.us wrote to
-> > rebel-
-> > >> builders:->
-> > >> -> -> Sean,
-> > >> -> -> The VAN's website shows a few air boxes for O-360's.
-> > >> Which one did
-> > >> you
-> > >> -> -> use? ... and was there any issues in rigging up carb heat?
-> > >> -> -> Bob 612e
-> > >> -> -> Original Message:
-> > >> -> -> From: kitplane_solutionsol.com
-> > >> -> -> Date: Thu, 11 Oct 2007 12:32:23 -0900
-> > >> -> -> To: rebel-builders@dcsol.com
-> > >> -> -> Subject: RE: [rebel-builders] EliteProp&airfilter
-> > >> -> -> No you must cut out the blade openings to many differents
-> > >> blades for
-> > >> one
-> > >> -> -> cut out
-> > >> -> -> Sean
-> > >> -> -> On 10/11/2007 4:39 AM, walter.klatt@shaw.ca wrote to
-> > rebel-
-> > >> builders:
-> > >> -> -> -> So these are fiberglass spinners? Are the blade cut-
-> > >> outs done?
-> > >> -> -> -> Walter
-> > >> -> -> -> -----Original Message-----
-> > >> -> -> -> From: mike.davis@dcsol.com
-> > >> [mailto:mike.davis@dcsol.com] On
-> > >> -> Behalf
-> > >> -> -> Of
-> > >> -> -> -> kitplane_solutions@dcsol.com
-> > >> -> -> -> Sent: Wednesday, October 10, 2007 8:35 PM
-> > >> -> -> -> To: rebel-builders@dcsol.com
-> > >> -> -> -> Subject: RE: [rebel-builders] EliteProp&airfilter
-> > >> -> -> -> The vans bulkheads are prepunched for the prop bolts
-> > >> but you
-> > >> need to
-> > >> -> -> put
-> > >> -> -> -> the dome attach scerws in this is easy beause you can
-> > >> see right
-> > >> -> through
-> > >> -> -> the
-> > >> -> -> -> fiberglass spinner to drill the holes
-> > >> -> -> -> Sean
-> > >> -> -> -> 10/10/2007 5:26 PM, walter.klatt@shaw.ca wrote to
-> > rebel-
-> > >> builders:-> -> ->
-> > >> -> -> -> -> Do the Vans spinners come all cut out and holes
-> > >> drilled for prop
-> > >> -> -> bolts?
-> > >> -> -> -> My
-> > >> -> -> -> -> last one I did from scratch with the Murphy kit, and
-> > >> it was a lot
-> > >> -> of
-> > >> -> -> -> work. I
-> > >> -> -> -> -> was happy with the final result, but like I said, I
-> > >> am getting real
-> > >> -> -> lazy
-> > >> -> -> -> now
-> > >> -> -> -> -> the second time around, and just want to get it back
-> > >> in the air
-> > >> -> ASAP.
-> > >> -> -> -> -> Walter
-> > >> -> -> -> -> -----Original Message-----
-> > >> -> -> -> -> From: mike.davis@dcsol.com
-> > >> On
-> > >> -> -> Behalf
-> > >> -> -> -> Of
-> > >> -> -> -> -> kitplane_solutions@dcsol.com
-> > >> -> -> -> -> Sent: Wednesday, October 10, 2007 8:24 PM
-> > >> -> -> -> -> To: rebel-builders@dcsol.com
-> > >> -> -> -> -> Subject: RE: [rebel-builders] EliteProp&airfilter
-> > >> -> -> -> -> Hi Walter
-> > >> -> -> -> -> The Vans airbox for the 360 carb or up draft fuel
-> > >> injection will
-> > >> -> -> work. It
-> > >> -> -> -> -> needs
-> > >> -> -> -> -> a little trim and a bit of glass work but will fit
-> > >> the Murphy cowl
-> > >> -> -> I've
-> > >> -> -> -> done
-> > >> -> -> -> -> three of them now and they seem to hang together
-> > >> just fine. I
-> > >> also
-> > >> -> -> use
-> > >> -> -> -> Vans
-> > >> -> -> -> -> tThrottle bracket and spinners they are really nice
-> > >> and are a very
-> > >> -> -> good
-> > >> -> -> -> -> price
-> > >> -> -> -> -> also. I joke that all of the planes that I build
-> > >> have a Van-Murphy
-> > >> -> -> fire
-> > >> -> -> -> wall
-> > >> -> -> -> -> forward package
-> > >> -> -> -> -> Sean
-> > >> -> -> -> -> On 10/10/2007 4:02 PM, walter.klatt@shaw.ca wrote
-> > >> rebel-
-> > >> -> builders:
-> > >> -> -> -> -> -> You mention Van's air filters. Does Van's sell a
-> > >> carb heat box
-> > >> -> for
-> > >> -> -> the
-> > >> -> -> -> -> 360
-> > >> -> -> -> -> -> that would fit the Murphy cowl and what would the
-> > >> part
-> > >> number
-> > >> -> -> be? I
-> > >> -> -> -> -> have
-> > >> -> -> -> -> -> their catalogue, but couldn't find that item.
-> > >> -> -> -> -> -> Also I am thinking of taking the lazy route and
-> > >> buying Van's
-> > >> -> -> baffles,
-> > >> -> -> -> -> too.
-> > >> -> -> -> -> -> The ones for the RV 6, 7, et al are part number
-> > >> BAF-6-360.
-> > >> Are
-> > >> -> -> these
-> > >> -> -> -> -> -> right ones?
-> > >> -> -> -> -> -> Also, where is the best place to get a good
-> > >> stainless steel
-> > >> -> exhaust
-> > >> -> -> -> for
-> > >> -> -> -> -> -> 360? I assume it is probably the same as for
-> > the 320?
-> > >> -> -> -> -> -> Walter
-> > >> -> -> -> -> -> -----Original Message-----
-> > >> -> -> -> -> -> From: mike.davis@dcsol.com
-> > >> -> On
-> > >> -> -> -> Behalf
-> > >> -> -> -> -> Of
-> > >> -> -> -> -> -> kitplane_solutions@dcsol.com
-> > >> -> -> -> -> -> Sent: Wednesday, October 10, 2007 2:20 PM
-> > >> -> -> -> -> -> To: rebel-builders@dcsol.com
-> > >> -> -> -> -> -> Subject: [rebel-builders] EliteProp&airfilter
-> > >> -> -> -> -> -> All Elite kits have been delivered with an airbox
-> > >> that fits an
-> > >> -> 360
-> > >> -> -> -> carb
-> > >> -> -> -> -> but
-> > >> -> -> -> -> -> airfilter is to small. I can't remeber the name
-> > >> of the person
-> > >> -> that
-> > >> -> -> I
-> > >> -> -> -> -> spoke
-> > >> -> -> -> -> -> to at
-> > >> -> -> -> -> -> Bracket but I was told that an 0-360 needs a
-> > >> minimum of
-> > >> 27
-> > >> -> -> square
-> > >> -> -> -> -> inchs of
-> > >> -> -> -> -> -> filter surface. If the supplied airbox is used it
-> > >> will fail in
-> > >> -> -> about
-> > >> -> -> -> 25
-> > >> -> -> -> -> -> hours of
-> > >> -> -> -> -> -> use this is do to the carb heat door vibrating
-> > >> from the engine
-> > >> -> -> trying
-> > >> -> -> -> to
-> > >> -> -> -> -> -> draw
-> > >> -> -> -> -> -> air from the back side of the door. The first
-> > >> Elite I built for
-> > >> -> Bob
-> > >> -> -> -> Fry
-> > >> -> -> -> -> had
-> > >> -> -> -> -> -> standard filter and ran like crap at full power
-> > >> while belching
-> > >> -> -> black
-> > >> -> -> -> -> smoke.
-> > >> -> -> -> -> -> Pulling the filter resulted in almost 200 RPM
-> > >> increase at full
-> > >> -> -> -> throttle.
-> > >> -> -> -> -> I
-> > >> -> -> -> -> -> modified the box for a larger filter (not easy)
-> > >> now I just put
-> > >> -> Vans
-> > >> -> -> -> air
-> > >> -> -> -> -> -> filters
-> > >> -> -> -> -> -> on and get it over with. Bob's plane is
-> > running a
-> > >> 76-56 prop
-> > >> -> and
-> > >> -> -> -> pulled
-> > >> -> -> -> -> 2460
-> > >> -> -> -> -> -> static at an OAT of about 90 this past summer.
-> > >> Bob cruises
-> > >> at
-> > >> -> 103
-> > >> -> -> kts.
-> > >> -> -> -> at
-> > >> -> -> -> -> -> 2480. This is an XP-360 with one Lightspeed. And
-> > >> it is still
-> > >> for
-> > >> -> -> sale
-> > >> -> -> -> -> take
-> > >> -> -> -> -> -> advantage of the Canuck Buck and buy it today
-> > >> -> -> -> -> -> Sean White
-> > >> -> -> -> -> -> List archives located at:
-> > >> https://mail.dcsol.com/login-> -> -> -> -> username
-> > >> "rebel" password "builder"
-> > >> -> -> -> -> -> Unsubscribe: rebel-builders-
-> > unsubscribe@dcsol.com>> -> -> -> -> -> List administrator:
-> > mike.davis@dcsol.com>> -> -> -> -> ->
-> > >> -> -> -> -> List archives located at:
-> > >> https://mail.dcsol.com/login-> -> -> -> username "rebel"
-> > >> password "builder"
-> > >> -> -> -> -> Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> > >> -> -> -> -> List administrator: mike.davis@dcsol.com
-> > >> -> -> -> List archives located at:
-> > https://mail.dcsol.com/login>> -> -> -> username "rebel"
-> > password "builder"
-> > >> -> -> -> Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> > >> -> -> -> List administrator: mike.davis@dcsol.com
-> > >> -> -> List archives located at: https://mail.dcsol.com/login
-> > >> -> -> username "rebel" password "builder"
-> > >> -> -> Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> > >> -> -> List administrator: mike.davis@dcsol.com
-> > >> -> -> mail2web.com - MicrosoftR Exchange solutions from a
-> > >> leading
-> > >> provider -
-> > >> -> -> http://link.mail2web.com/Business/Exchange
-> > >> -> List archives located at: https://mail.dcsol.com/login
-> > >> -> username "rebel" password "builder"
-> > >> -> Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> > >> -> List administrator: mike.davis@dcsol.com
-> > >> List archives located at: https://mail.dcsol.com/login
-> > >> username "rebel" password "builder"
-> > >> Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> > >> List administrator: mike.davis@dcsol.com
-> > > List archives located at: https://mail.dcsol.com/login
-> > > username "rebel" password "builder"
-> > > Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> > > List administrator: mike.davis@dcsol.com
Robert Andrews
Post by Robert Andrews » Sun Feb 19, 2012 7:01 pm
Roger. Checked the archives for a picture of a VANS air box install ... no
joy. Any chance you could upload a few? Sean, your experience and lessons
learned with this is most appreciated.
Cheers, Bob 612e
Sent: Saturday, October 13, 2007 9:45 AM
Subject: RE: RE: [rebel-builders] EliteProp&airfilter
without
Sean
air
-> box?
-> Bob 612e
-> WALTER KLATT
-> Walter
-> > same?? Bob J
-> > have one of
-> > > Walter
-> > >> need a 2"
-> > >> includes a
-> > >> magnet and
-> > >> Sean
-> > builders:>>
-> > >> -> Walter
-> > >> Behalf
-> > >> Of
-> > >> -> Sean
-> > rebel-
-> > >> builders:->
-> > >> -> -> Sean,
-> > >> you
-> > >> blades for
-> > >> one
-> > >> -> -> Sean
-> > rebel-
-> > >> builders:
-> > >> outs done?
-> > >> -> Behalf
-> > >> -> -> Of
-> > >> but you
-> > >> need to
-> > >> -> -> put
-> > >> see right
-> > >> -> through
-> > >> -> -> the
-> > rebel-
-> > >> -> -> -> My
-> > >> -> of
-> > >> -> -> lazy
-> > >> in the air
-> > >> -> ASAP.
-> > >> On
-> > >> -> -> -> Of
-> > >> -> -> I've
-> > >> also
-> > >> -> -> use
-> > >> -> -> good
-> > >> -> -> fire
-> > >> rebel-
-> > >> -> for
-> > >> -> -> the
-> > >> part
-> > >> number
-> > >> -> -> be? I
-> > >> BAF-6-360.
-> > >> Are
-> > >> -> -> these
-> > >> -> exhaust
-> > the 320?
-> > >> -> On
-> > >> -> 360
-> > >> -> that
-> > >> -> -> I
-> > >> minimum of
-> > >> 27
-> > >> -> -> about
-> > >> -> -> -> 25
-> > >> -> -> -> to
-> > >> -> Bob
-> > >> -> -> black
-> > >> -> Vans
-> > running a
-> > >> 76-56 prop
-> > >> -> and
-> > >> Bob cruises
-> > >> at
-> > >> -> 103
-> > >> -> -> kts.
-> > >> -> -> -> at
-> > >> it is still
-> > >> for
-> > >> -> -> sale
-> > >> leading
-> > >> provider -
Robert Andrews
box?
Bob 612e
WALTER KLATT
same?? Bob J
Sounds very good.
have one of
need a 2"
includes a
filters both
magnet and
when ever it
You do not have
important if you
heat on as it is
Sean
builders:>>
-> Walter
Behalf
Of
-> Sean
rebel-
builders:->
-> -> Sean,
Which one did
you
-> -> Bob 612e
blades for
one
-> -> cut out
-> -> Sean
rebel-
builders:
outs done?
-> -> -> Walter
-> Behalf
-> -> Of
but you
need to
-> -> put
see right
-> through
-> -> the
-> -> -> Sean
rebel-
builders:-> -> ->
drilled for prop
-> -> bolts?
-> -> -> My
it was a lot
-> of
-> -> -> work. I
am getting real
-> -> lazy
-> -> -> now
in the air
-> ASAP.
-> -> -> -> Walter
On
-> -> Behalf
-> -> -> Of
injection will
-> -> work. It
-> -> -> -> needs
the Murphy cowl
-> -> I've
-> -> -> done
just fine. I
also
-> -> use
-> -> -> Vans
and are a very
-> -> good
-> -> -> -> price
have a Van-Murphy
-> -> fire
-> -> -> wall
-> -> -> -> Sean
-> -> -> -> On 10/10/2007 4:02 PM, walter.klatt@shaw.ca wrote to
rebel-
-> builders:
carb heat box
-> for
-> -> the
-> -> -> -> 360
part
number
-> -> be? I
-> -> -> -> have
buying Van's
-> -> baffles,
-> -> -> -> too.
BAF-6-360.
Are
-> -> these
-> -> -> the
stainless steel
-> exhaust
-> -> -> for
-> -> -> -> the
the 320?
-> On
-> -> -> Behalf
-> -> -> -> Of
that fits an
-> 360
-> -> -> carb
-> -> -> -> but
-> -> -> -> -> the
of the person
-> that
-> -> I
-> -> -> -> spoke
minimum of
27
-> -> square
will fail in
-> -> about
-> -> -> 25
from the engine
-> -> trying
-> -> -> to
-> -> -> -> -> draw
Elite I built for
-> Bob
-> -> -> Fry
-> -> -> -> had
-> -> -> -> -> the
while belching
-> -> black
-> -> -> -> smoke.
increase at full
-> -> -> throttle.
-> -> -> -> I
now I just put
-> Vans
-> -> -> air
running a
76-56 prop
-> and
-> -> -> pulled
-> -> -> -> 2460
Bob cruises
at
-> 103
-> -> kts.
-> -> -> at
it is still
for
-> -> sale
-> -> -> -> take
password "builder"
password "builder"
leading
provider -
Post by Walter Klatt » Sun Feb 19, 2012 7:01 pm
Sean
-> Sean,
-> Bob 612e
-> cut out
-> Sean
-> -> Walter
Behalf
-> Of
-> put
through
-> the
-> -> Sean
-> bolts?
-> -> My
-> -> work. I
-> lazy
-> -> now
ASAP.
-> -> -> Walter
-> Behalf
-> -> Of
-> -> -> Hi Walter
-> work. It
-> -> -> needs
-> I've
-> -> done
-> use
-> -> Vans
-> good
-> -> -> price
-> fire
-> -> wall
-> -> -> Sean
builders:
for
-> the
-> -> -> 360
-> be? I
-> -> -> have
-> baffles,
-> -> -> too.
-> these
-> -> the
exhaust
-> -> for
-> -> -> the
-> -> -> -> Walter
On
-> -> Behalf
-> -> -> Of
360
-> -> carb
-> -> -> but
-> -> -> -> the
that
-> I
-> -> -> spoke
-> -> -> -> to at
-> square
-> -> -> inchs of
-> about
-> -> 25
-> trying
-> -> to
-> -> -> -> draw
Bob
-> -> Fry
-> -> -> had
-> -> -> -> the
-> black
-> -> -> smoke.
-> -> throttle.
-> -> -> I
Vans
-> -> air
-> -> -> -> filters
-> -> pulled
-> -> -> 2460
103
-> kts.
-> -> at
-> sale
-> -> -> take
-> mail2web.com - MicrosoftR Exchange solutions from a leading provider -
kitplane_solutions
It does come with all the bits to assemble the door but you will need a 2"
flange to attach the scat hose to your heat muff. Vans also includes a
alternate air door kit to bypass the filter as the normal setup filters both
warm and cold air. The original bypass door was held close by a magnet and
was to open itself if the filter plugged but was found to open when ever it
felt like it. They now have a cable operated door in its place. You do not have
to install this door if you are not flying in heavy snow or freezing rain as it is
olny there in case you pack the air filter full of ice and snow important if you
fly a lot of IFR. If you are ever in dought just pull the carb heat on as it is
Sean
On 10/12/2007 10:18 AM, walter.klatt@shaw.ca wrote to rebel-builders:
-> Walter
Of
-> Sean
-> On 10/11/2007 12:42 PM, robert@montanasky.us wrote to rebel-builders:
-> -> Sean,
-> -> The VAN's website shows a few air boxes for O-360's. Which one did
you
-> -> Bob 612e
-> -> No you must cut out the blade openings to many differents blades for
one
-> -> cut out
-> -> Sean
-> -> On 10/11/2007 4:39 AM, walter.klatt@shaw.ca wrote to rebel-
builders:
-> -> -> So these are fiberglass spinners? Are the blade cut-outs done?
-> -> -> Walter
-> Behalf
-> -> Of
-> -> -> The vans bulkheads are prepunched for the prop bolts but you
need to
-> -> put
-> -> -> the dome attach scerws in this is easy beause you can see right
-> through
-> -> the
-> -> -> Sean
-> -> -> 10/10/2007 5:26 PM, walter.klatt@shaw.ca wrote to rebel-builders:
-> -> -> -> Do the Vans spinners come all cut out and holes drilled for prop
-> -> bolts?
-> -> -> My
-> -> -> -> last one I did from scratch with the Murphy kit, and it was a lot
-> of
-> -> -> work. I
-> -> -> -> was happy with the final result, but like I said, I am getting real
-> -> lazy
-> -> -> now
-> -> -> -> the second time around, and just want to get it back in the air
-> ASAP.
-> -> -> -> Walter
On
-> -> Behalf
-> -> -> Of
-> -> -> -> The Vans airbox for the 360 carb or up draft fuel injection will
-> -> work. It
-> -> -> -> needs
-> -> -> -> a little trim and a bit of glass work but will fit the Murphy cowl
-> -> I've
-> -> -> done
-> -> -> -> three of them now and they seem to hang together just fine. I
also
-> -> use
-> -> -> Vans
-> -> -> -> tThrottle bracket and spinners they are really nice and are a very
-> -> good
-> -> -> -> price
-> -> -> -> also. I joke that all of the planes that I build have a Van-Murphy
-> -> fire
-> -> -> wall
-> -> -> -> Sean
-> -> -> -> On 10/10/2007 4:02 PM, walter.klatt@shaw.ca wrote to rebel-
-> builders:
-> -> -> -> -> You mention Van's air filters. Does Van's sell a carb heat box
-> for
-> -> the
-> -> -> -> 360
-> -> -> -> -> that would fit the Murphy cowl and what would the part
number
-> -> be? I
-> -> -> -> have
-> -> -> -> -> Also I am thinking of taking the lazy route and buying Van's
-> -> baffles,
-> -> -> -> too.
-> -> -> -> -> The ones for the RV 6, 7, et al are part number BAF-6-360.
Are
-> -> these
-> -> -> the
-> -> -> -> -> Also, where is the best place to get a good stainless steel
-> exhaust
-> -> -> for
-> -> -> -> the
-> -> -> -> -> 360? I assume it is probably the same as for the 320?
-> On
-> -> -> Behalf
-> -> -> -> Of
-> -> -> -> -> All Elite kits have been delivered with an airbox that fits an
-> 360
-> -> -> carb
-> -> -> -> but
-> -> -> -> -> the
-> -> -> -> -> airfilter is to small. I can't remeber the name of the person
-> that
-> -> I
-> -> -> -> spoke
-> -> -> -> -> Bracket but I was told that an 0-360 needs a minimum of
27
-> -> square
-> -> -> -> -> filter surface. If the supplied airbox is used it will fail in
-> -> about
-> -> -> 25
-> -> -> -> -> use this is do to the carb heat door vibrating from the engine
-> -> trying
-> -> -> to
-> -> -> -> -> draw
-> -> -> -> -> air from the back side of the door. The first Elite I built for
-> Bob
-> -> -> Fry
-> -> -> -> had
-> -> -> -> -> the
-> -> -> -> -> standard filter and ran like crap at full power while belching
-> -> black
-> -> -> -> smoke.
-> -> -> -> -> Pulling the filter resulted in almost 200 RPM increase at full
-> -> -> throttle.
-> -> -> -> I
-> -> -> -> -> modified the box for a larger filter (not easy) now I just put
-> Vans
-> -> -> air
-> -> -> -> -> on and get it over with. Bob's plane is running a 76-56 prop
-> and
-> -> -> pulled
-> -> -> -> 2460
-> -> -> -> -> static at an OAT of about 90 this past summer. Bob cruises
at
-> 103
-> -> kts.
-> -> -> at
-> -> -> -> -> 2480. This is an XP-360 with one Lightspeed. And it is still
for
-> -> sale
-> -> -> -> take
-> -> -> -> -> List archives located at: https://mail.dcsol.com/login
-> -> -> -> -> username "rebel" password "builder"
-> -> -> -> -> Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> -> -> -> -> List administrator: mike.davis@dcsol.com
-> -> mail2web.com - MicrosoftR Exchange solutions from a leading
provider -
WALTER KLATT
Post by WALTER KLATT » Sun Feb 19, 2012 7:01 pm
Sounds very good.
Now I also need a new speed cowl and a dynafocal mount. Anyone have one of these they don't need?
need a 2"
includes a
filters both
magnet and
when ever it
You do not have
important if you
heat on as it is
Sean
-> Walter
Behalf
Of
-> Sean
builders:->
-> -> Sean,
Which one did
you
-> -> Bob 612e
blades for
one
-> -> cut out
-> -> Sean
builders:
outs done?
-> -> -> Walter
-> Behalf
-> -> Of
but you
need to
-> -> put
see right
-> through
-> -> the
-> -> -> Sean
builders:-> -> ->
drilled for prop
-> -> bolts?
-> -> -> My
it was a lot
-> of
-> -> -> work. I
am getting real
-> -> lazy
-> -> -> now
in the air
-> ASAP.
-> -> -> -> Walter
On
-> -> Behalf
-> -> -> Of
injection will
-> -> work. It
-> -> -> -> needs
the Murphy cowl
-> -> I've
-> -> -> done
just fine. I
also
-> -> use
-> -> -> Vans
and are a very
-> -> good
-> -> -> -> price
have a Van-Murphy
-> -> fire
-> -> -> wall
-> -> -> -> Sean
rebel-
-> builders:
carb heat box
-> for
-> -> the
-> -> -> -> 360
part
number
-> -> be? I
-> -> -> -> have
buying Van's
-> -> baffles,
-> -> -> -> too.
BAF-6-360.
Are
-> -> these
-> -> -> the
stainless steel
-> exhaust
-> -> -> for
-> -> -> -> the
-> On
-> -> -> Behalf
-> -> -> -> Of
that fits an
-> 360
-> -> -> carb
-> -> -> -> but
-> -> -> -> -> the
of the person
-> that
-> -> I
-> -> -> -> spoke
minimum of
27
-> -> square
will fail in
-> -> about
-> -> -> 25
from the engine
-> -> trying
-> -> -> to
-> -> -> -> -> draw
Elite I built for
-> Bob
-> -> -> Fry
-> -> -> -> had
-> -> -> -> -> the
while belching
-> -> black
-> -> -> -> smoke.
increase at full
-> -> -> throttle.
-> -> -> -> I
now I just put
-> Vans
-> -> -> air
76-56 prop
-> and
-> -> -> pulled
-> -> -> -> 2460
Bob cruises
at
-> 103
-> -> kts.
-> -> -> at
it is still
for
-> -> sale
-> -> -> -> take
password "builder"
leading
provider -
Robert Johnson
Post by Robert Johnson » Sun Feb 19, 2012 7:01 pm
Hi Walter: I have a dynafocal mount for an O320 - are they the same?? Bob J
Sounds very good.
need a 2"
includes a
filters both
magnet and
when ever it
You do not have
important if you
heat on as it is
Sean
-> Walter
Behalf
Of
-> Sean
builders:->
-> -> Sean,
Which one did
you
-> -> Bob 612e
blades for
one
-> -> cut out
-> -> Sean
builders:
outs done?
-> -> -> Walter
-> Behalf
-> -> Of
but you
need to
-> -> put
see right
-> through
-> -> the
-> -> -> Sean
builders:-> -> ->
drilled for prop
-> -> bolts?
-> -> -> My
it was a lot
-> of
-> -> -> work. I
am getting real
-> -> lazy
-> -> -> now
in the air
-> ASAP.
-> -> -> -> Walter
On
-> -> Behalf
-> -> -> Of
injection will
-> -> work. It
-> -> -> -> needs
the Murphy cowl
-> -> I've
-> -> -> done
just fine. I
also
-> -> use
-> -> -> Vans
and are a very
-> -> good
-> -> -> -> price
have a Van-Murphy
-> -> fire
-> -> -> wall
-> -> -> -> Sean
rebel-
-> builders:
carb heat box
-> for
-> -> the
-> -> -> -> 360
part
number
-> -> be? I
-> -> -> -> have
buying Van's
-> -> baffles,
-> -> -> -> too.
BAF-6-360.
Are
-> -> these
-> -> -> the
stainless steel
-> exhaust
-> -> -> for
-> -> -> -> the
-> On
-> -> -> Behalf
-> -> -> -> Of
that fits an
-> 360
-> -> -> carb
-> -> -> -> but
-> -> -> -> -> the
of the person
-> that
-> -> I
-> -> -> -> spoke
minimum of
27
-> -> square
will fail in
-> -> about
-> -> -> 25
from the engine
-> -> trying
-> -> -> to
-> -> -> -> -> draw
Elite I built for
-> Bob
-> -> -> Fry
-> -> -> -> had
-> -> -> -> -> the
while belching
-> -> black
-> -> -> -> smoke.
increase at full
-> -> -> throttle.
-> -> -> -> I
now I just put
-> Vans
-> -> -> air
76-56 prop
-> and
-> -> -> pulled
-> -> -> -> 2460
Bob cruises
at
-> 103
-> -> kts.
-> -> -> at
it is still
for
-> -> sale
-> -> -> -> take
password "builder"
leading
provider -
WALTER KLATT
same?? Bob J
Sounds very good.
have one of
need a 2"
includes a
filters both
magnet and
when ever it
You do not have
important if you
heat on as it is
Sean
builders:>>
-> Walter
Behalf
Of
-> Sean
rebel-
builders:->
-> -> Sean,
Which one did
you
-> -> Bob 612e
blades for
one
-> -> cut out
-> -> Sean
rebel-
builders:
outs done?
-> -> -> Walter
-> Behalf
-> -> Of
but you
need to
-> -> put
see right
-> through
-> -> the
-> -> -> Sean
rebel-
builders:-> -> ->
drilled for prop
-> -> bolts?
-> -> -> My
it was a lot
-> of
-> -> -> work. I
am getting real
-> -> lazy
-> -> -> now
in the air
-> ASAP.
-> -> -> -> Walter
On
-> -> Behalf
-> -> -> Of
injection will
-> -> work. It
-> -> -> -> needs
the Murphy cowl
-> -> I've
-> -> -> done
just fine. I
also
-> -> use
-> -> -> Vans
and are a very
-> -> good
-> -> -> -> price
have a Van-Murphy
-> -> fire
-> -> -> wall
-> -> -> -> Sean
rebel-
-> builders:
carb heat box
-> for
-> -> the
-> -> -> -> 360
part
number
-> -> be? I
-> -> -> -> have
buying Van's
-> -> baffles,
-> -> -> -> too.
BAF-6-360.
Are
-> -> these
-> -> -> the
stainless steel
-> exhaust
-> -> -> for
-> -> -> -> the
the 320?
-> On
-> -> -> Behalf
-> -> -> -> Of
that fits an
-> 360
-> -> -> carb
-> -> -> -> but
-> -> -> -> -> the
of the person
-> that
-> -> I
-> -> -> -> spoke
minimum of
27
-> -> square
will fail in
-> -> about
-> -> -> 25
from the engine
-> -> trying
-> -> -> to
-> -> -> -> -> draw
Elite I built for
-> Bob
-> -> -> Fry
-> -> -> -> had
-> -> -> -> -> the
while belching
-> -> black
-> -> -> -> smoke.
increase at full
-> -> -> throttle.
-> -> -> -> I
now I just put
-> Vans
-> -> -> air
running a
76-56 prop
-> and
-> -> -> pulled
-> -> -> -> 2460
Bob cruises
at
-> 103
-> -> kts.
-> -> -> at
it is still
for
-> -> sale
-> -> -> -> take
password "builder"
password "builder"
leading
provider -
Robert Andrews
Thanks for uploading the pics Sean ... their worth 1000 words and more.
Looks like the air box inlet is bigger then would be for a VANS installation
... no mods to the lower cowl .. true?
Bob 612e
Robert Andrews
Sent: Saturday, October 13, 2007 9:21 AM
Cheers, Bob 612e
without
Sean
air
-> box?
-> Bob 612e
-> WALTER KLATT
-> Walter
-> > same?? Bob J
-> > have one of
-> > > Walter
-> > >> need a 2"
-> > >> includes a
-> > >> magnet and
-> > >> Sean
-> > builders:>>
-> > >> -> Walter
-> > >> Behalf
-> > >> Of
-> > >> -> Sean
-> > rebel-
-> > >> builders:->
-> > >> -> -> Sean,
-> > >> you
-> > >> blades for
-> > >> one
-> > >> -> -> Sean
-> > rebel-
-> > >> builders:
-> > >> outs done?
-> > >> -> Behalf
-> > >> -> -> Of
-> > >> but you
-> > >> need to
-> > >> -> -> put
-> > >> see right
-> > >> -> through
-> > >> -> -> the
-> > rebel-
-> > >> -> -> -> My
-> > >> -> of
-> > >> -> -> lazy
-> > >> in the air
-> > >> -> ASAP.
-> > >> On
-> > >> -> -> -> Of
-> > >> -> -> I've
-> > >> also
-> > >> -> -> use
-> > >> -> -> good
-> > >> -> -> fire
-> > >> rebel-
-> > >> -> for
-> > >> -> -> the
-> > >> part
-> > >> number
-> > >> -> -> be? I
-> > >> BAF-6-360.
-> > >> Are
-> > >> -> -> these
-> > >> -> exhaust
-> > the 320?
-> > >> -> On
-> > >> -> 360
-> > >> -> that
-> > >> -> -> I
-> > >> minimum of
-> > >> 27
-> > >> -> -> about
-> > >> -> -> -> 25
-> > >> -> -> -> to
-> > >> -> Bob
-> > >> -> -> black
-> > >> -> Vans
-> > running a
-> > >> 76-56 prop
-> > >> -> and
-> > >> Bob cruises
-> > >> at
-> > >> -> 103
-> > >> -> -> kts.
-> > >> -> -> -> at
-> > >> it is still
-> > >> for
-> > >> -> -> sale
-> > >> leading
-> > >> provider -
