[rebel-builders] Fuel Tank
Post by Walter Klatt » Sun Feb 19, 2012 2:39 pm
Just thought I would emphasize what Wayne said about the importance of only
having the rear outlets. It seems that this is a popular misconception out
there with some homebuilders, not just Murphy planes, where they think 2
outlets are safer.
I know of another plane where some builders had installed a front outlet as
well, and to make it worse, the engine also had a fuel pump. Well, it didn't
take long for engine outs to occur when tanks were low, and during an
initial steep climb. Needless to say, this was a hard lesson for some.
With the Rebel, you need to also be aware that if you have the tank shut off
valves up top at the rear of the tanks, instead of the bottom, you can
easily get an air block in the lines when switching tanks, if you run one
tank dry in the air and don't use the correct tank switching procedure. More
specifically, if you are running on one tank, let it go dry, close it, then
open the other tank, your engine will quit, guaranteed, every time. I proved
this myself, on the ground, and it is very repeatable.
The correct procedure is to open the other full side first, and when the
engine is confirmed to keep running OK, then the empty tank can be closed.
What happens with the incorrect sequence, is that air is sitting in your
lines below the valves, and if you close your empty one, it can not escape
when the full one is opened.
This is a very important point to understand if you don't want any rude
surprises some day when switching tanks.
Sent: Friday, February 02, 2007 9:25 AM
Subject: Re: [rebel-builders] Fuel Tank
You would have to stuff the nose VERY hard to unport the fuel fitting even
low on fuel. Double porting also negates the syphon effect the fuel line
would have with just the rear port, as when you get low on fuel as it will
draw air from the front port easier than fuel from the back, especially if
you are running a fuel pump. Even the old style of fuel gauge sight
fitting
tee'd into the main outlet stopped the syphon ability of the tank.
Starting
with an empty tank it would take adding 10 gallons of fuel to the tank....
to get fuel to flow to the carb on FOKM before I changed the site gauge
set
up to a seperate isolated fitting. After moving it fuel flow became almost
instant with the first few gallons added to the tank.
Kim Kimball
Post by Kim Kimball » Sun Feb 19, 2012 2:42 pm
I thought some Cessnas had two outlets.
044SR
Date: Friday, February 2, 2007 11:25 am
Subject: RE: [rebel-builders] Fuel Tank
importance of only
misconception out
think 2
outlets are safer.
outlet as
it didn't
tank shut off
run one
procedure. More
it, then
time. I proved
when the
closed.What happens with the incorrect sequence, is that air is
sitting in your
not escape
rudesurprises some day when switching tanks.
Behalf Of
fitting even
fuel line
as it will
especially if
fitting
Starting
the tank....
site gauge
set
became almost
Post by Ken » Sun Feb 19, 2012 2:42 pm
I buy cheap numbered bits both ways. Usually I use 135* split point for
#40 but 118* plain for #30.
steve whitenect wrote:
I always use 135* split point drills to avoid skating on any light or thin
surfaces and I meant 3/32" as to the best of my short learned brain, the
numbered drills are straight cut. But have been wrong many times before!!
Steve W 637R
Jesse Jenks
Post by Jesse Jenks » Sun Feb 19, 2012 2:42 pm
Walter,
I'm planning to use an Andair valve in the floor, and delete the shutoff
valves in the wing root. Do you think the same problem could occur if I run
a tank dry and immediatly switch to the other one instead of going to both?
Thanks.
Jesse
Date: Fri, 02 Feb 2007 12:19:58 -0800
outlets are safer.
didn't
off
More
proved
even
will
if
fitting
Starting
tank....
set
almost
Check out all that glitters with the MSN Entertainment Guide to the Academy
Awards
Post by Walter Klatt » Sun Feb 19, 2012 2:42 pm
No, if the valve is on the bottom, the air in the lines will always be able
to escape upwards into the tank. It's the valves on top when closed that
will trap the air.
Another consideration, though, about where to put your tank valves, has to
do with unplanned off airport landing events. It might be preferable to
close your valves up top by your wings prior to the landing attempt, to
avoid fuel in the cabin, should your lines rip between the wings and the
bottom valve. A broken landing gear could do it, especially the old bungee
type, if your fuel lines run along the bottom sides as per the MAM original
instructions.
So there are pros and cons here with both methods.
Jesse Jenks
Sent: Saturday, February 03, 2007 10:59 AM
Walter,
run
both?
Thanks.
Jesse
only
out
outlets are safer.
as
didn't
off
More
then
proved
closed.
escape
even
line
will
especially
if
fitting
Starting
tank....
gauge
set
almost
Academy
AwardsR http://movies.msn.com/movies/oscars2007 ... artagline2
Post by Mike Kimball » Sun Feb 19, 2012 2:42 pm
In addition to Bob's reason to retain the fuel shutoff valves in the wing
root I was sure glad to have them when I developed leaks at virtually all of
my flare fittings under the floor (suspect poor quality flare tool). If you
want to do any maintenance on the fuel lines it sure is nice to shut off the
fuel up there. I found some nice bulkhead valves so that the valve is on
the outside of the fuselage with the handle on the inside. I also have the
Andair four position selector valve on the floor between the seats.
044SR
Jenks
Sent: Saturday, February 03, 2007 9:59 AM
Walter,
Thanks.
Jesse
outlets are safer.
didn't
off
More
proved
even
will
if
fitting
Starting
tank....
set
almost
Jesse Jenks
Thanks Walter and Mike,
Mike, where did you get the valves you mention?
Jesse
Date: Sat, 03 Feb 2007 18:01:04 -0900
you
044SR
Jenks
Walter,
Thanks.
Jesse
only
out
outlets are safer.
as
didn't
off
More
then
proved
closed.
escape
even
line
will
especially
if
fitting
Starting
tank....
gauge
set
almost
Get in the mood for Valentine's Day. View photos, recipes and more on your
Live.com page.
http://www.live.com/?addTemplate=Valent ... MSN30A0701
I knew someone would ask about the fuel valves. I'll look it up and get
back to you. I think you'll like them. The valve handle is probably half
the length of the one's supplied by MAM with the valve pivot in the middle
of the handle instead of on the end and provides a nice, neat installation.
044SR
Jenks
Sent: Saturday, February 03, 2007 7:05 PM
Jesse
you
044SR
Jenks
Walter,
Thanks.
Jesse
only
out
outlets are safer.
as
didn't
off
More
then
proved
closed.
escape
even
line
will
especially
if
fitting
Starting
tank....
gauge
set
almost
Live.com page.
Jesse Jenks
Cool!
Thanks Mike.
Date: Sat, 03 Feb 2007 22:06:14 -0900
044SR
Jenks
Jesse
you
044SR
Jesse
Jenks
Walter,
run
both?
Thanks.
Jesse
only
out
2
outlets are safer.
outlet
as
didn't
shut
off
one
More
then
proved
closed.
your
escape
Of
fitting
even
line
it
will
especially
if tank....
gauge
almost
Academy
Live.com page.
From predictions to trailers, check out the MSN Entertainment Guide to the
Academy Awards
The fuel valves I used were from McMaster Carr, part number 4114T25. Here
is a link to their catalog page.
http://www.mcmaster.com/nav/enter.asp?pagenum=387
I used valves with 3/8NPT fittings and installed NPT to flare adapters.
Since the 1/4NPT fittings (4114T23) are half the price of the 3/8 fittings I
would recommend ... well, guess.
Kimball
Sent: Saturday, February 03, 2007 10:06 PM
044SR
Jenks
Jesse
you
044SR
Jenks
Walter,
Thanks.
Jesse
only
out
outlets are safer.
as
didn't
off
More
then
proved
closed.
escape
even
line
will
especially
if
fitting
Starting
tank....
gauge
set
almost
Live.com page.
Jesse Jenks
Thanks for the link Mike! Those do look cool.
Jesse
Date: Sun, 04 Feb 2007 17:45:07 -0900
Kimball
044SR
Jenks
Jesse
you
044SR
Jesse
Jenks
Walter,
run
both?
Thanks.
Jesse
only
out
2
outlets are safer.
outlet
as
didn't
shut
off
one
More
then
proved
closed.
your
escape
Of
fitting
even
line
it
will
especially
if tank....
gauge
almost
Academy
Live.com page.
Search for grocery stores. Find gratitude. Turn a simple search into
something more.
http://click4thecause.live.com/search/c ... ORM=WLMTAG
Post by Wayne G. O'Shea » Mon Feb 20, 2012 2:35 am
Just sounds like two different brands of sealer Rick. Slosh is generally
yellow (dries semi clear), white or red.
Sent: Wednesday, December 07, 2011 10:20 PM
Subject: [rebel-builders] Fuel Tank
I've cut 3"x5" hole on top of fuel tanks,0ne side is proseal ,the other
is a light tan colour ,thin surface covering substance.Would this beType A
brushable sealant or slosh coating. Rick 233R
rick greenwood
Post by rick greenwood » Mon Feb 20, 2012 2:35 am
I kind of thought so, but wanted to know for sure.Thanks Wayne. Rick
Date: Wed, 7 Dec 2011 22:48:51 -0500
