Sorry to hear of your many troubles - certainly haven't
seen so much trouble here.... Over 1,000 hours on the first one,
NO parts replaced !
The rivets would shear - that's why we all have "Ontario Mod. #1"
- the FUS-30 doubler (see photo in files) !
I would never think about using that chunk of aluminum called
a "spring" !! At the very least, it should be ground to taper to
1/2 thickness by the tailwheel end ... I <only> use the original
fiberglass 'springs' - they work great, and have a very benign
failure mode - they delaminate eventually ! :-)
Don't know what the problem with the roll pins in the plate
might be - second time I've heard of this - perhaps the size or
material has changed .... Anybody know ???
Also, the sliding lock pin <was> steel - if I understand Drew,
it is now BRASS ???? That would obviously not wear nearly as well !
My concern with the spring you use being too 'bouncy' is that,
taxiing on rough ground, it could be bouncing the tail up into the
air, slamming the tailwheel down too hard, and possibly twisting
sideways as well, putting much higher than normal loads on those
pins & the bushings !!! Too much bounce can be a 'bad thing',
and only a single leaf might twist too easily. :-(
The fiberglass has some internal damping ...
Sorry - NO idea where to get the fiberglass springs now -
Aircraft Spruce DID sell them a few years ago .... Might have
to fabricate my next one myself ! ;-)
On Saturday 08 October 2005 09:34 pm, IAN DONALDSON wrote:
occasions.G'day bobp
Thanks for your response.
I'm glad to learn that you have had a successful time with your standard
Murphy tailwheel, but I can't say the same about mine! :-(
Here are some of the problems encountered so far.
The rivets in the tail cone sheared due to the rigidity of the factory
supplied aluminium "spring."
The two 1/8' roll pins that hold the cam plate have broken on two
ThisThe cams on locking mechanism have worn down so quickly that I have had to
build them up with weld twice.
The 1/8" pins that holds the wheel fork to the central spindle sheared.
inmeant that the wheel was uncontrollable.
The aluminum housing is now worn so badly that I will have to put a bush
andit to take up the slack on the central spindle.
All these problems have arisen despite me being diligent in maintenance
thegreasing as needed. Maybe the problems that I have encountered with the
wheel are perhaps due to our Australian conditions, but as far as I am
concerned the quality of the Murphy wheel is definitely not acceptable.
I regards to the replacement spring, I don't know what you mean by "a bit
too bouncy" or what difference that it would make to the operation of the
wheel. The spring that I am using now seems to be OK and it is certainly
much kinder to the rear of the rebel than the standard "spring".
I am aware of the weight difference and will do a new weight and balance
calculation before making the change to the Scott. Would you know what
homeweight of a standard wheel is? I could then do my W&B calculations at
before pulling the wheel off my Rebel.
regards
Ian Donaldson
I'm very surprised that you had problems with the original
tailwheel - unless you rounded the ends of the locking pin ....
maybe the spring you're using is a bit tooo bouncy ! :-)
The standard factory setup has worked great for me on 3 Rebels,
and many more I've flown - no problems.
I'd be very careful about adding a Scott 3200 to a 912 Rebel !
The C of G is already pretty far back, and 8+ lb. at the tail
could cause serious problems. Would be worth re-calculating to
be safe !
