Prop extension
Rebflyer
Prop extension
Post by Rebflyer » Sat Feb 18, 2012 12:35 pm
I'm begining to wonder aabout my e-mail out bound. I have a 3.5 with the
7/16 bolt holes and the 4.75 pattern. I believe it came from a 0-320 on a 172.
I dropped Dale a line but I guess it did not go through. Hate to run #'s on
this page but 25.00 plus shipping sounds good to me.
Also, I dropped you a line off site too Wayne, did you get it? I have
some questions about selling and delivering a kitfox to Ontario from Michigan.
Do you have any helpful hints? I tried to do it off page but I guess the
server I was going through wouldn't let me. Phone #'s would be great. Curt
Rebflyer
Prop extension
Whoops, It is 3/8 bolts not 7/16. Curt
Fred Darnell
Prop Extension
Post by Fred Darnell » Sat Feb 18, 2012 1:39 pm
I'm trying to finish up my Super Rebel with an IO-540 and Hartzell
constant speed prop. The manual calls out a 2" prop spacer and judging
from the curvature of the lower cowl and the amount the starter
protrudes, I'm guessing the 2" is required. Does anyone know where to
get these 2" prop spacers and are the even appropriate with the 260hp
IO-540? Hartzell (at least the tech support guy I talked to) was helpful
but knew nothing of a spacer. My prop is HC-C2YK-1BF/F8477-2.
Fred Darnell
SR066
rognal
Prop Extension
Post by rognal » Sat Feb 18, 2012 1:39 pm
Fred,
For my IO-240/Rebel I purchased a prop spacer from:
Saber Manufacturing, Inc.
3601 Nassau Court
Granbury, TX 76049
817-326-6293
Sam Tilleman-Proprietor
The company was recommended to me by Charley Denny at Sensenich. The spacer
is very well made, machined, and finished. $462.00 USD for a two inch spacer,
crush plate, bolts, etc. Your cost may vary...
Roger Hoffman #687R
Eugene, OR USA!
Al Paxhia
Prop Extension
Post by Al Paxhia » Sat Feb 18, 2012 1:39 pm
Fred,
I did not use a spacer with my IO540 with a Hartzell HC-C3YR-1RF/F8475R.
What manual are you referring to?
Al
Sent: Wednesday, June 15, 2005 8:27 PM
Subject: Prop Extension
Fred Darnell
SR066
Dale Fultz
Prop Extension
Post by Dale Fultz » Sat Feb 18, 2012 1:39 pm
Hi Al, in the instructions for the cowling it says to put a 2 inch
extension on to mount to. Dale SR 033
Sent: Thursday, June 16, 2005 6:25 AM
Subject: Re: Prop Extension
Fred,
Al
Fred Darnell
SR066
Fred Darnell
Prop Extension
Al,
Murphy confirmed the instructions are for the 4 cyl. Elite. I have a few
questions to ask you directly based on your experience with this prop.
If you don't mind either email me your phone number or call me at
704-509-9411. Your help would be very appreciated. Thanks.
Fred
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Al
Paxhia
Sent: Thursday, June 16, 2005 9:25 AM
Fred,
Al
helpful but knew nothing of a spacer. My prop is HC-C2YK-1BF/F8477-2.
Fred Darnell
SR066
password "builder" Subscription services located at:
fdarnell
Prop Extension
Post by fdarnell » Sat Feb 18, 2012 1:39 pm
Thanks Al and Dale. I just got a confirmation from Murphy that a spacer is
intended for the 4 cyl / Elite installation.
When I mounted my spinner on the crank prop flange it seemed my starter
protruded too far forward and interfered with the lower cowl and I began to
suspect an extension would be necessary. I think the ring-gear mounted
spinner I had was the problem. I've learned from several others that a
flange mounted spinner is best. Once I have one I'll try again.
Al, what spinner do you have?
Thanks for the help.
On Thu, 16 Jun 2005 08:33:50 -0700 Dale Fultz <dfultz17086@earthlink.net>
wrote.
Fred,
Al
Fred Darnell
SR066
Schmucker, Del
prop extension
Post by Schmucker, Del » Sun Feb 19, 2012 7:31 pm
I am making some changes on my Rebel and may be looking to purchase a
prop extension either 4 or 6 inch. Wondering if anyone has one that
they might to get rid of??
Thank you,
Del Schmucker
Information Systems Manager
807-223-1254
807-221-8769 Cell
807-223-4703 Fax
del.schmucker@kpdsb.on.ca
www.kpdsb.on.ca
