engine mount
engine mount
Post by Wayne G. O'Shea » Sat Feb 18, 2012 3:04 am
Sounds like you did what you should. I must be thinking of someone else that
had their firewall loosening off etc that was also flying an O-360 on
straight floats out there in BC.
I've never checked to see whether the tubes are flexing, the rubbers or what
have you on mine. It's always been this way from the day I installed the
original O-235 to today with the O-320. 8 years later and it hasn't fallen
off or got any worse! Mine is a Conical mount! Is yours Conical or
Dynafocal??
Sent: Wednesday, November 26, 2003 10:44 PM
Subject: Re: engine mount
Hi Wayne I believe I called you about 4 1/2 years ago about firewall. I
did
beef up firewall with doublers or should I say stiffeners back to back on
top of firewall and doublers on mounts riveted too witches hat,doublers on
floor .Also put in float bars from overhead cage to firewall stiffeners. I
built my Rebel with .032 corner wraps from firewall back to baggage
dept..The only problem I have had is rivets in door hinge on cage smoking
,I
have went up one size larger and longer and seems to be working fine.
About
motor mount when I mention the movement to the two AME I know they say it
should not move or flex like that so I always have that question in the
back
of my mind that there is something wrong.A friend of mine with a Rebel
with
a conical mount 0-320 engine does not move. THANKS jerry
Sent: Wednesday, November 26, 2003 6:51 PM
Ditto! I can move my motor up and down and at the spinner center I see
about
5/8 movement. If it didn't move, something would break! (I could move
O-470 on my C182 around a lot more than that!!)
Jerry, wasn't it you that called me close to a year back about your
firewall
moving around? and I suggested that you had too much "umph" on the nose
that Rebel? Especially considering it didn't sound like you had any
reinforcement plates on the firewall. MAM's Elite style or "others" that
are
available.
Sent: Wednesday, November 26, 2003 9:46 PM
Just out of curiosity do you know of any mounts that don't flex?
Where exactly is your mount flexing, and under what conditions is it
flexing.
Grant.
engine mount
Jerry, if you want to cut it down some you can buy harder aerobatic lord
mount rubbers. But take your bank manager with you! :o))
Sent: Wednesday, November 26, 2003 11:20 PM
Hi again Wayne: my is a dynafocal,purchased from Murphy, I feel the rubber
mounts are to soft but do not really know, but the amount of movement
sounds
about the same as yours.I hope it is okay I guess I'm looking for peace of
mind on movement,have about 400 hrs now and keep on checking for cracks in
mount.THANKS FOR YOUR TIME REALLY APPRECIATE: jerry
Sent: Wednesday, November 26, 2003 7:48 PM
that
what
fallen
Dynafocal??
did
on
hat,doublers
on
stiffeners.
smoking
,I
About
it
back
with
see
about
move
firewall
nose
that
are
it
Jean Poirier
Engine mount
Post by Jean Poirier » Sun Feb 19, 2012 2:34 pm
Hello
I am looking for a Rebel engine mount for a Lycoming 0-235.
Jean
Rebel 747R
Jean Poirier
Pr
Jean Poirier
Engine mount
Post by Jean Poirier » Sun Feb 19, 2012 2:52 pm
Hello
I am looking for Lycoming conical engine mount for a Rebel (part number
E-79). Let me know if you have one for sale
Jay Yau
Engine mount
Post by Jay Yau » Sun Feb 19, 2012 9:23 pm
Does any one know where to buy the engine mount for Rebel, for O-320 Mattituck engine? what's the approx price?
Jay
Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox.
http://www.windowslive.com/campaign/the ... P:042010_1
schaumr
engine mount
Post by schaumr » Sun Feb 19, 2012 11:34 pm
Hi All,
I am getting ready to have an engine mount built for my 6-cyl Corvair engine.
It'll produce about 120hp, and weigh a bit less than an O-200 installed.
Virtually all Corvair mounts are bed mounts, and I've decided to have William
Wynne (of flycorvair.com) weld it up for me. He has welded Corvair mounts
for a number of othe aircraft, and I am looking for reference materials to
provide to him: schematics (if possible), thrust lines, distances from firewall
for CG, etc...
I am hoping someone has a schematic of a Rebel with an O-235 engine install
(or even an O-320) to get a sense of the required dimensions.
Can anyone tell me if these documents exist?
Thanks in advance,
Rob
wayne.pederson
engine mount
Post by wayne.pederson » Sun Feb 19, 2012 11:34 pm
Lycoming 0-235 width of holes is 11.50", up and down is 9.56" center thrust
line is 5" down from top holes
On 12/18/2010 10:38 AM, schaumr wrote to builders:
-> Hi All,
-> I am getting ready to have an engine mount built for my 6-cyl Corvair
engine.
-> It'll produce about 120hp, and weigh a bit less than an O-200 installed.
-> Virtually all Corvair mounts are bed mounts, and I've decided to have
William
-> Wynne (of flycorvair.com) weld it up for me. He has welded Corvair
mounts
-> for a number of othe aircraft, and I am looking for reference materials to
-> provide to him: schematics (if possible), thrust lines, distances from
firewall
-> for CG, etc...
-> I am hoping someone has a schematic of a Rebel with an O-235 engine
install
-> (or even an O-320) to get a sense of the required dimensions.
-> Can anyone tell me if these documents exist?
-> Thanks in advance,
-> Rob
wayne.pederson
engine mount
I forgot to post the distance from the firewall is 11.50" when using a spin on
oil filter
-> Hi All,
engine.
William
mounts
firewall
-> for CG, etc...
install
-> Rob
Jim Parr
Engine mount
Post by Jim Parr » Sun Feb 19, 2012 11:51 pm
We have a kit that came with the dynafocol mount. But we came across an 0290 zero timed cheap that takes a straight mount. Anyone out there give me some measurements for making a straight mount? distance from firewall, angles, anything would help.
Jim
705R
