a two part twin syringe dispenser. It works GREAT on plastics and sticks to
metal pretty good too. Hold your nose when you mix it, stinks really bad.
I think it is an epoxy with some type on plastic solvent mixed in. If you
put a bit on some plastic then wipe it off the surface will be dulled like
it etched it or something. I've even used it to repair broken teeth on
plastic gears. Just not sure if it's fuel proof.
Joel Jacobs
Sent: Thursday, May 22, 2003 8:38 AM
Subject: Re: Plastic to Brass/alum fitting sealer?
toI read a 2 part epoxy package the other day and it stated "does not stick
anyway.any plastics"! Guess you proved them wrong aye!!!!
Sent: Thursday, May 22, 2003 2:06 AM
This may seem like a bailing wire fix, but I thought I'd share it
minuteItank...bought a snow machine 3 years ago with a split/leaking plastic fuelI took a wire brush to the crack to rough things up, then worked 30
it'sarea.epoxy into the crack and spread it out on the surrounding "roughed up"3 years later and many hours of bouncing down the trails at -30F, and
goingstill holding.
Sounds to simple... but if it works, why not!
Sent: Wednesday, May 21, 2003 3:53 PM
Thanks Dave!
I'm going to tackle it somehow tomorrow and if they still leak I'm
*-------------------------------------------------------------------------*outtorip the tank lids off the wings and build him some real aluminum tanksof my own "pocket"....... as in the long run it will cost me less!!
Thanks again everyone,
