[203.21.25.179]) by host02.net.voyager.co.nz (8.8.8/8.6.12) with ESMTP id
MAA20393 for <murphy-rebel@dcsol.com>; Fri, 22 Jan 1999 12:23:35 +1300
(NZDT)
Message-Id: <199901212323.MAA20393@host02.net.voyager.co.nz>
Subject: Re: Spring Gear fix ???
Date: Fri, 22 Jan 1999 12:22:23 +1300
X-MSMail-Priority: Normal
X-Priority: 3
X-Mailer: Microsoft Internet Mail 4.70.1155
MIME-Version: 1.0
Content-Type: text/plain; charset=ISO-8859-1
Jim,
No, you're right, it ain't no Maule! It's Better!!!
I think we've got to keep things in perspective here, with the problems
I've had with the gear, engine mount etc. you would think I would have
every right to feel a bit brassed off with the whole thing. In fact I am
not, admittedly pulling the aircraft to bits again was a real pain, but the
end result is really worth it. I've got an aircraft here that is just the
envy of everyone. A few weeks back I teamed up with a 235hp Maule and we
headed south to fiordland and spent day doing the airstrips in that area,
some of them are really challenging. With similar payloads my Rebel
performed every bit as good as the Maule, take off distances were very
similar, landing distances a bit shorter, the Maule had to pull a bit of
power back to stay with me in the cruise but when we pulled up to the fuel
pump I know which aircraft I would rather be filling up!
The visibility is absolutely stunning in the Rebel and it is the sort of
aircraft you just 'strap on your back' and fly away. Obviously being on
experimental and with a brand new airframe, maintenance costs are way back
on that of a Maule. And for less money you own a new aircraft verses
something decades old.
The Maule pilot came back blown away by the capabilities of the Rebel, his
statement was " That has got to be the best plane in New Zealand!" I, of
course, agreed!!!
These issues in regards to the 'Floatfix' and spring gear etc. just have to
be worked through, the end result is a aircraft that you can have complete
confidence in.
All issue I've dealt with regarding the Rebel have been when the the
aircraft comes in contact with the ground (and rough ground at that!), and
as you say hanging heavier motors on the front, in the air, it's bullet
proof. Work through those problems and the road is clear ahead.
Stay positive !!
Alister
first setFrom: James A. Remington <jaremington@earthlink.net>
To: (Murphy Rebel) <murphy-rebel@dcsol.com>
Date: Friday, January 22, 1999 11:16 AM
Alister: The set I have now is a replacement for the first set. The
to awas so bad that the left and right leg were off by 3 inches when clamped
amounttable and one had positive camber and the other had negative camber. No
would haveof shims could have corrected that. Goodness knows how the aircraft
lowertracked on the ground and one wing tip would have been a least a foot
for athan the other. The second set was just about as bad so I did not try
set.third set. Again, no wedges or instructions were included with either
theOn a different tact, I doubt if the aircraft was ever designed to take
point.concentrated torque load that this spring gear generates at the attach
slap onYour fix may have resolved that but Murphy's approach to all of these
structural failures is to 1) deny they exist 2) when that won't work,
seata doubler of paper thin aluminum and hope it goes away.
This has been the case with cracks due to ever increasing engine weight,
thinkfailures, tail cone buckling, etc. I realize it is an experimental but I
pointsMurphy lets his ego and the bottom line get ahead of owning up to weak
alsoand letting all kit owners know of potential problems. We kit owners are
harmonyat fault for taking an overgrown ultralight and trying to make it into an
C172. The original design wasn't bad. Everything was basically in
things onincluding that 80 HP rotax. When we keep hanging heavier and heavier
theythat airframe, I think we are asking for trouble. It ain't no Maule!
jar
Alister Yeoman wrote:
Jim,
You've tried Murphy for a replacement on them? If they are not right
aboutshould be replaced, mine were absolutely perfect!
Alister
----------From: James A. Remington <jaremington@earthlink.net>
Date: Friday, January 22, 1999 7:05 AM
Alister: I showed the gear to an EAA friend who knows a good bit
thatsuchsoftened, bentthings and he said that to make them match they would have to bedone by aand then tempered again to the original condition. This work must beshop that really know heat treating of aluminum. He is also the one
theysaidthe legs should have been gun drilled for the hydraulic lines before
springwerebent the first time.
Jim
hasgear
combinationitsinstructionsbetween
thatofcaster
with,step.considerbookends.Murphy
cheaperitsolid
supplied
theinthem. I
aircraft,fuse.bigger
isI
visibleabookusingrear of
youbut
blockwould
make
wasany
Hangingverythey
twothe
aircraftgearwondering
thetothey
toouterdiameter
ofthecorneragainstmove aquite
thenthe
from
athe
AN3factinserts
to doreally
have
sortedbeen
outerby
butgear
is
leftno
rowsoffrolled
bolts,of
andthis
850-6
rough
more
about
itany
stengthen
it.the
