Fuel Caps
Legeorgen
Fuel Caps
Post by Legeorgen » Fri Feb 17, 2012 11:47 pm
Mike,
I believe the intent in cross venting was to get even fuel flow, even in the
event one vent may get plugged.
Bruce G
Fuel Caps
Post by Wayne G. O'Shea » Fri Feb 17, 2012 11:47 pm
Your right there Bruce! It is a safety feature to insure both tanks are
vented if some bugs clog one sides vent up (if you are using two vent tubes)
, but the most important thing it does is to equalize the pressure in both
tanks to get EVEN fuel flow from both tanks, when you are cranking and
banking!
Regards,
Sent: Saturday, March 03, 2001 11:55 AM
Subject: Re: Fuel Caps
Mike,
Bruce G
murphy-rebel mailing list.
AGT
Fuel Caps
Post by AGT » Fri Feb 17, 2012 11:47 pm
OK. After all the great discussion, here's my new plan. Cross fitting to
give me a three way tee at each upper sight tube fitting, right at the wing
root. Inverted J fittings, with the slight mod that Bob P. mentions to get
the tube opening pointed more into the wind. Then a cross tube between the
fittings to connect the tanks together.
Sent: Saturday, March 03, 2001 8:43 AM
banking!
Regards,
Mike,
Bruce G
apat
Fuel Caps
Post by apat » Fri Feb 17, 2012 11:47 pm
Received: from smtp.interlog.com ([154.11.89.176])
by dcsol.com (wcSMTP v5.4.449.1)
with SMTP id 674943421; Sat, 03 Mar 2001 18:34:25 -0900
Received: (qmail 7346 invoked from network); 4 Mar 2001 03:34:21 -0000
Received: from unknown (HELO ip56.toronto84.dialup.canada.psi.net) (154.20.78.56)
by bretweir.total.net with SMTP; 4 Mar 2001 03:34:21 -0000
Mime-Version: 1.0
Subject: RE: Fuel Caps
Hi Mike !
Sounds good !! Might be a good idea to do as Wayne suggests,
and drill a 1/16" or so hole on the back of the front 'up' part of
the "J", to let water escape out the back instead of pushing into the tank...
(and don't forget a bit of window screen in the front bottom to keep
the bugs out ;-) )
....bobp
--------------------------------orig.-----------------------------------
banking!
Regards,
Mike,
Bruce G
Fuel Caps
Wasn't my suggestion, but sounds good!
Sent: Saturday, March 03, 2001 10:34 PM
(154.20.78.56)
Mime-Version: 1.0
Hi Mike !
tank...
the bugs out ;-) )
....bobp
wing
get
tubes)
both
banking!
Regards,
Mike,
in
Bruce G
AGT
Fuel Caps
Gotcha! Thanks!
APAT@ISTAR.CA
Sent: Saturday, March 03, 2001 6:35 PM
(154.20.78.56)
Mime-Version: 1.0
Hi Mike !
tank...
the bugs out ;-) )
....bobp
tubes)
banking!
Regards,
Mike,
Bruce G
