Odyssey Battery
Legeorgen
Odyssey Battery
Post by Legeorgen » Sat Feb 18, 2012 12:22 am
Someone mentioned Odyssey batteries last week, so I looked them up on a web
page and learned the PC625, recommended battery for a Lycoming 0320, was a 16
AH battery. The battery Gill Cell recomends for this engine is a 25 AH
battery. I like the thought of a 13lb. battery but is it large enough to do
the job? Has anyone been using this battery on a Lycoming 0320 and what is
your experience with it?
Bruce G
Odyssey Battery
Post by Wayne G. O'Shea » Sat Feb 18, 2012 12:22 am
Bruce, that's what I had put on the firewall for Charles and it cranked his
O-235 over really well. Same 6.5 to 1 compression ratio as your 0-320 will
be, if 150 HP. The Rebel I repaired this spring had an Odyssey battery ( I
think next size up) mounted way down in the tailcone and it cranked over the
O-320 (WITH O-540 cylinders on it!!) "lickidy split"!
Sent: Sunday, December 02, 2001 9:56 PM
Subject: Re: Odyssey Battery
web
16
do
Bruce G
LisaFly99
Odyssey Battery
Post by LisaFly99 » Sat Feb 18, 2012 12:22 am
BRUCE
I have the PC800 Odessy mounted way back in the tail cone. It cranks the heck
out of a 2.2 soob.
Phil&Lisa Smith
#460R
N414D
Keith Oliver
Odyssey Battery
Post by Keith Oliver » Sat Feb 18, 2012 12:22 am
I am wondering if standard starters were used or perhaps an aftermarket ??
Also what do O-540 cylinders do for you on an O-320 ??
Keith Oliver
Elite #654 TD
N654ME (reserved)
Farmingdale, Maine
Sent: Sunday, December 02, 2001 11:02 PM
web
16
do
Bruce G
Legeorgen
Odyssey Battery
Phil,
If I remember right, your battery (the next size up) weighed in at 24lb. Is
this correct?
Bruce G
LisaFly99
Odyssey Battery
In a message dated 12/3/01 9:03:45 PM Central Standard Time, Legeorgen@cs.com writes:
Phil,
this correct?
Bruce G
YES. I think my total with custom made aluminum battery box and battery the weight came to 27 LB. I REALLY need to climb back in there and double check. I have the total weight written on the out side of the box.
Phil&Lisa Smith
N414D
