Mike,
I believe the intent in cross venting was to get even fuel flow, even in the
event one vent may get plugged.
Bruce G
Fuel Caps
Fuel Caps
Your right there Bruce! It is a safety feature to insure both tanks are
vented if some bugs clog one sides vent up (if you are using two vent tubes)
, but the most important thing it does is to equalize the pressure in both
tanks to get EVEN fuel flow from both tanks, when you are cranking and
banking!
Sent: Saturday, March 03, 2001 11:55 AM
Subject: Re: Fuel Caps
banking!
theMike,
*---------------------------------------------------------------------------event one vent may get plugged.
Bruce G
*---------------------------------------------------------------------------You have received this message because you have subscribed to the
murphy-rebel mailing list.
AGT
Fuel Caps
OK. After all the great discussion, here's my new plan. Cross fitting to
give me a three way tee at each upper sight tube fitting, right at the wing
root. Inverted J fittings, with the slight mod that Bob P. mentions to get
the tube opening pointed more into the wind. Then a cross tube between the
fittings to connect the tanks together.
Sent: Saturday, March 03, 2001 8:43 AM
banking!
banking!
theMike,
Bruce G
apat
Fuel Caps
Received: from smtp.interlog.com ([154.11.89.176])
by dcsol.com (wcSMTP v5.4.449.1)
with SMTP id 674943421; Sat, 03 Mar 2001 18:34:25 -0900
Received: (qmail 7346 invoked from network); 4 Mar 2001 03:34:21 -0000
Received: from unknown (HELO ip56.toronto84.dialup.canada.psi.net) (154.20.78.56)
by bretweir.total.net with SMTP; 4 Mar 2001 03:34:21 -0000
Mime-Version: 1.0
Subject: RE: Fuel Caps
Hi Mike !
Sounds good !! Might be a good idea to do as Wayne suggests,
and drill a 1/16" or so hole on the back of the front 'up' part of
the "J", to let water escape out the back instead of pushing into the tank...
(and don't forget a bit of window screen in the front bottom to keep
the bugs out ;-) )
....bobp
--------------------------------orig.-----------------------------------
Mime-Version: 1.0
Hi Mike !
the bugs out ;-) )
....bobp
banking!
*-------------------------------------------------------------------------**-------------------------------------------------------------------------*The list archives are located at:
theMike,
I believe the intent in cross venting was to get even fuel flow, even in*---------------------------------------------------------------------------event one vent may get plugged.
Bruce G
---**---------------------------------------------------------------------------You have received this message because you have subscribed to the
----*You have received this message because you have subscribed to the
Fuel Caps
Wasn't my suggestion, but sounds good!
Sent: Saturday, March 03, 2001 10:34 PM
(154.20.78.56)Received: from smtp.interlog.com ([154.11.89.176])
tank...by bretweir.total.net with SMTP; 4 Mar 2001 03:34:21 -0000
Mime-Version: 1.0
Hi Mike !
to(and don't forget a bit of window screen in the front bottom to keep
the bugs out ;-) )
....bobp
username: rebel password: builderOK. After all the great discussion, here's my new plan. Cross fitting
winggive me a three way tee at each upper sight tube fitting, right at the
getroot. Inverted J fittings, with the slight mod that Bob P. mentions to
thethe tube opening pointed more into the wind. Then a cross tube between
tubes)*-------------------------------------------------------------------------*fittings to connect the tanks together.
username: rebel password: builderYour right there Bruce! It is a safety feature to insure both tanks are
both, but the most important thing it does is to equalize the pressure in
in*-------------------------------------------------------------------------*tanks to get EVEN fuel flow from both tanks, when you are cranking and
banking!
Mike,
-*--------------------------------------------------------------------------theevent one vent may get plugged.
Bruce G
list-server@dcsol.com---*You have received this message because you have subscribed to the
-*--------------------------------------------------------------------------with "unsubscribe murphy-rebel" in the body of the message.
----**--------------------------------------------------------------------------You have received this message because you have subscribed to the
AGT
Fuel Caps
Gotcha! Thanks!
APAT@ISTAR.CA
Sent: Saturday, March 03, 2001 6:35 PM
(154.20.78.56)
Mime-Version: 1.0
Hi Mike !
tank...
the bugs out ;-) )
....bobp
APAT@ISTAR.CA
(154.20.78.56)
Mime-Version: 1.0
Hi Mike !
tank...
the bugs out ;-) )
....bobp
-, but the most important thing it does is to equalize the pressure in both
banking!
theMike,
I believe the intent in cross venting was to get even fuel flow, even in*--------------------------------------------------------------------------event one vent may get plugged.
Bruce G
