[rebel-builders] Float Hydraulics Check Valves and pump o ri
[rebel-builders] Float Hydraulics Check Valves and pump o rings
Post by Drew Dalgleish » Mon Feb 20, 2012 2:36 am
Hi Nig Haven't had to change the o rings yet but the check valves are
a common industrial part. I got replacements at the local hose headquarters.
On 16/01/2012 10:48 AM, N.Smith wrote:
Hi All
Anyone changed the o rings in their amphib gear pump and any idea what size
they are ?
Also, anyone got a source for the two check valves located at the pump
inlet/outlet ?
Nig
745E
