your patterns after getting the frame work all togther and transfer to .020
or .025 sheet. To avoid getting any puckers in your doors always put a hand
underneath as you pull it around the firewall corner and into position...or
when fitting find something about 6" in diameter and hand bend the door
around it slightly.
Unfortunately my construction pics of the 4 door cowling are pre digital for
me...so I only have them in my albums and no scanner currently working in
the house.
I took some more recently pics of the completed 4 door cowl for others that
were posted in the archives...but think they were lost. Will dig them back
up and repost when I can.
Mainly the channels are built from flat sheet, two angles and two hinges per
channel. This gives a nice "fork" for each end so it can slip over the
firewall lip and nose bowl lip. Anchor nuts are secured to the angle piece
ends so this gives the hole in the outer flat panel, the nose bowl (or
firewall lip) for the screw to go thru first and then thread into the anchor
nut.
There are a couple pics on my website www.irishfield.on.ca in the "services"
section..."engine installations"..."O-235" but will dig you up some more!
To: "Rebel List" <rebel-builders@dcsol.com>
Sent: Friday, November 26, 2004 4:45 PM
Subject: SR Chevy engine mount and Cowl
toMy engine mount is nearing completion. I just uploaded two new pictures
mountthe SR engine section. Finger straps and gussets still need to be added
here and there. Also, a horizontal tube between the two upper engine
thepoints on the firewall will be added to stiffen the mount. If you pull
mostupper bolt on one side as it is now the mount still has a lot of flex.
Instead of relying on the channel riveted to the firewall to account for
this we decided we wanted the mount to be stiff on it's own.
I discussed Ken's comments with my mount builder and I think most of Ken's
concerns are addressed by the cross pieces that are now visible in the
belowrecent pics that I uploaded. Downward forces on the rear mount points are
accounted for with the tube from the upper fuselage point to the point
input.the rear engine mount point. Outward forces on the rear mount point are
accounted for with the cross pieces at the lower rear of the mount that
weren't in the original pics. The rear mount points are now the apex of a
four point pyramid. Although I know adding a tube from the top firewall
points to the rear engine mount points would add strength, I'm not sure it
is necessary with the current configuration. The tube in it's current
position definitely has less of a bending moment on it then a tube going
directly from the firewall points to the engine mount points would. I'm
going to take one last look at it this weekend and make a final decision
about whether or not to add another tube. Thanks again Ken for your
1-inchI am now looking ahead to the cowling. I wonder if Bob and others could
tell me more about the channels used to begin building the four door cowl?
I have asked Murphy to quote me on three channels just like the one on the
firewall between the upper mount points but five feet in length. I was
thinking that I could use those as the left, right, and upper channels to
start the four door cowl idea. I think they are 3-inch channels with
flanges made from something like 0.040 or 0.062 aluminum. (I'm not in my
shop - just guessing from memory). Next, I still want to find an
off-the-shelf nose bowl that would work. Any ideas on that? Lastly, I'm
hoping that I can simply form the cowl skins by hand somehow since I don't
have a sheet metal roller. Any ideas on that? HELP! Thanks
SR044
