[rebel-builders] Pro Seal
Jean Poirier
Post by Jean Poirier » Sun Feb 19, 2012 2:00 pm
Hello Aurele
You can have semple kit from leavens (1-800-263-6142) . If not I have a
account with A.P.I. in Montreal. I can order it for you if they do not want
to sale to you (1-800-214-7404)
Jean
Rebel 747R
P.S.: With a name like that you should speak french!
Jean Poirier
Pr
Aurele Lavigne
Post by Aurele Lavigne » Sun Feb 19, 2012 2:00 pm
Thanks Jean, I'll try Leavans. What is API ???
Of course I'm french, but I figured my chances of a response on this list
was a little better in english, lol.
Merci, Aurele
From: "Jean Poirier" <jean.poirier@oxyportneuf.com>
Sent: Monday, July 24, 2006 1:10 PM
Subject: Re: [rebel-builders] Pro Seal
[quote]Hello Aurele
want
Jean
Rebel 747R
Jean Poirier
Pr
Post by Ken » Sun Feb 19, 2012 2:00 pm
Think they are called Semkits and they come in 2 oz. or 3.5 oz. size.
The small one should be fine but the intent of those kits is that you
mix the whole thing. With difficulty they can be taken apart and mixed
in two lots. Might be worth asking if they have any time expired ones as
they clear those quite a bit cheaper when they have them.
Type B means filleting which is what you probably want. B2 means 2 hour
working time. B 1/2 would likely also be fine.
Jean Poirier wrote:
[quote]Hello Aurele
Jean
Rebel 747R
Jean Poirier
Pr
Jean Poirier
API is a BIG distributor of aircraft supply who have a lots of location all
across north america. They usually just sale to retailer.... but as you
can see at the bottom I do owned a business and I have been able to open a
account using it!
Jean Poirier
Pr
Jean Poirier
Aurele,
Where are you located?
Jean Poirier
Pr
Aurele Lavigne
Hearst, where are you?
Aurele
Sent: Monday, July 24, 2006 2:56 PM
[quote]Aurele,
Jean Poirier
Pr
Jean Poirier
St-Basile-de-Portneuf (CTR6)
Between Quebec city and Trois-Riviere on the north shore of St-Laurence .
Jean Poirier
Pr
NormIsler
Post by NormIsler » Sun Feb 19, 2012 9:24 pm
Hi Jim
I'm pretty sure what you are describing is what Murphy provided for
installation of the windshield, although this does not appear to be the
recommended method for installing windshields. (Check the archives for more
information on windshield installation.)
A two part epoxy primer is the recommended material for dipping rivets and
brushing onto mating surfaces when assembling so as not to give corrosion a
place to start. Poly Fiber Epoxy Primer EP420 along with Catalyst EP430 is
the recommended material for that job.
A 2 part Proseal is used for sealing the fuel tanks.
Hope this helps!
Norm Isler
Elite 702E
Jim Parr
Post by Jim Parr » Sun Feb 19, 2012 9:24 pm
Thanks Norm,
we are just getting going on the wings and Dad said it was calling for some
Pro Seal. We don't have the 2 part stuff. Any idea what the number on it
is and where to get it?
Jim
705R
Sent: Sunday, June 20, 2010 6:12 PM
Hi Jim
more
Hope this helps!
Norm Isler
Elite 702E
Curtis Langholz
Post by Curtis Langholz » Sun Feb 19, 2012 9:24 pm
Jim,
That is a little hard to beleive! Don't know anything about the single part stuff. If I remember correctly you need the quart size of the two part Pro-Seal for both tanks. It does have a shelf life to it so you won't need it till you get close to doing the tanks.
Curtis
175R
Subject: [rebel-builders] Pro Seal
Date: Sun, 20 Jun 2010 17:33:48 -0600
Just going throught the stuff we got with our kit and we have one 10 oz tube of Bostich Pro Seal 1 part. I find it hard to believe that that one tube is going to do everything that needs to be done and I am not even sure that it is the correct stuff for the kit. When we looked in Aircraft Spruce's catalogue the Pro Seal (2 different kinds) is not the same. Can anyone tell me what the correct stuff is and where is the best place to get it. Also about how much should I get?
Jim Parr
705R
Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox.
http://www.windowslive.com/campaign/the ... P:042010_1
Curtis Langholz
Quart size pn# 09-38565 ACS.
Subject: RE: [rebel-builders] Pro Seal
Date: Sun, 20 Jun 2010 18:03:13 -0700
Jim,
Curtis
175R
Jim Parr
705R
