Automotive: a vegetable base product, clear in color, it will remove
automotive type paint when you spill it, seams to absorb moisture.
Requires seals compatible to vegetable base fluid.
Aviation: Mineral base product, Mil Spec 5606, red in color, maintains
its viscosity over a wide temperature range. 5606 does not remove
paint. It is the standard in all production airplanes. Fire resistant,
requires seals compatible with mineral based fluids. Most brake parts
come with seals compatible to this fluid
Synthetic: Such as Skydrol (phosphate ester base). It is used mostly in
the Airliners with large capacity systems, very good as a fire resistant
fluid. Very irritating to the eyes nose & throat. It requires seals
compatible to synthetic fluid. It maintains its viscosity over a big
temperature range. If given a choice I would never work with it again!!!
If you one time get it in your eyes you will share my feelings.
I would urge you to use the 5606 mineral based hydraulic fluid for its
proven reliability and compatibility to the industry standard. It is
available from almost all aviation vendors, repair shops and mechanics.
I would not want to run the risk of some one helping you out by
servicing your system with the wrong fluid and causing one big problem.
When fluid types are mixed the fluid can become very thick, seals swell
up and the whole system requires extensive repair, flushing etc.
Dick Wampach SR-108 N331RW
Ron Shannon
Sent: Monday, August 31, 2009 4:25 PM
Subject: Re: [rebel-builders] Brake Lines
I'm about to tackle this soon myself. On other Rebels, I've seen both
aluminum and and steel right angle AN fittings coming out the cabin
floor.
In the past, I've found a wide assortment of less common fittings in
both
materials at Summit Racing (http://summitracing.com) and Pegasus Racing
http://www.pegasusautoracing.com).
It's my understanding traditional brake fluid is corrosive to aluminum.
Of
course, a trip to the archives reveals the consensus recommended fluid
for
Rebel brakes seems to be Dextron automatic transmission fluid. Whether
that's corrosive to aluminum or not I don't know. If it isn't, I'll use
aluminum fittings.
Hope that helps. No doubt, others more knowledgeable than I will
contribute
answers too.
On Mon, Aug 31, 2009 at 4:06 PM, David L. Tuck <dltuck53@hotmail.com>
wrote:
cylinders toI'm in the process of fitting the brake lines from the master
like tothe gear legs, In what way are you exitting the cabin area? I would
use a 90 degree fitting the flex tubing on down the gear leg.
Can't seem to come up with a 90 bulkhead fitting to use with the brass
nylaflow plastic lines.
Does anyone have any input for this?
Dave T
rebel 009
