[rebel-builders] Rebel Parking Brake
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:07 pm
Fly with your wife... make her hold the airplane !
Other than that wheel chalks or the tie down area... brakes locked on a hot
summer day on the ramp is asking for blown calipers and or lines IMHO.
To: "Rebel Builders" <rebel-builders@dcsol.com>
Sent: Wednesday, January 14, 2009 6:11 PM
Subject: [rebel-builders] Rebel Parking Brake
Group:
The archive comments are a bit sparse on this question of three years ago.
What is the opinion of installing a parking brake system on the
Rebel/Elite, specifically on amphibs? How many out there have installed
the valve (tail dragger or amphib)? Necessary?
Thanks in advance for any comments.
Terry Dazey
R662
robert
Post by robert » Sun Feb 19, 2012 8:07 pm
I'm exploring adding parking brakes too. I agree on all Wayne stated. But when flying solo, having a temporary parking brake activated from the pilot seat while securing the aircraft is a plus. Once secured by other means (like tie downs), going back and releasing the parking brake is certainly a good idea. Bob, 612e
------Original Message------
Sender: mike.davis@dcsol.com
ReplyTo: rebel-builders@dcsol.com
Sent: Jan 14, 2009 3:15 PM
Subject: Re: [rebel-builders] Rebel Parking Brake
Group:
Terry Dazey
R662
Sent via BlackBerry by AT&T
Post by Ken » Sun Feb 19, 2012 8:07 pm
Fairly easy to install a holding valve but make sure it has a positive
off position and can't inadvertantly be activated in flight. (Landing
with it on is not recommended...) I paid about $20. for a used valve.
I use it all the time during warmup when I'm heads down playing with
gps, seat belts, maps etc. and consider it a worthwhile safety feature.
It is also occasionaly handy to hold the plane until I get the chocks in
but I've found that to be very rare. Don't think I've ever noticed one
in any other Rebel though.
Terry Dazey wrote:
Group:
What is the opinion of installing a parking brake system on the Rebel/Elite, specifically on amphibs? How many out there have installed the valve (tail dragger or amphib)? Necessary?
Terry Dazey
R662
EbeySlough
Post by EbeySlough » Sun Feb 19, 2012 8:07 pm
Hi;
I have an extra matco parking brake valve listed at aircraft spruce for
$113.95 that I will sell for $65.00. It was used on my Rebel for actuating the
landing gear up and down before I changed it out. It is hardly used and
perfectly OK. I went back to the Murphy manual valve for gear actuation. Richard
.......Rebel 706DV
message dated 1/14/2009 4:29:56
P.M. Pacific Standard Time, klehman@albedo.net writes:
Terry Dazey wrote:
Group:
Terry Dazey
R662
**************A Good Credit Score is 700 or Above. See yours in just 2 easy
steps!
(http://pr.atwola.com/promoclk/100000075 ... 2%26bcd=De
cemailfooterNO62)
Terry Dazey
Post by Terry Dazey » Sun Feb 19, 2012 8:07 pm
Hello Dick:
I have sent you an email direct to you at ebyslough address.
Terry
Sent: Jan 15, 2009 4:51 AM
Hi;
.......Rebel 706DV
Terry Dazey wrote:
Group:
Terry Dazey
R662
steps!
cemailfooterNO62)
Terry Dazey
Post by Terry Dazey » Sun Feb 19, 2012 8:11 pm
Thanks Wayne, Bob, Charlie, Ken and the rest about the need for a parking brake valve in a rebel.
Seems for the past 21 years, I have been performing my Long-EZ parking routine with no need for a parking brake. Just stop the prop, lower the nose, chalk the main gear tires and tie her down. No need for parking brake there.
On the Rebel, a parking brake system is probably not a necessity, but sounded like a good idea to me. Sooooo, I think that I will purchase a valve and necessary hardware and give it a try. The cons are that it will add build time, weight and complexity which goes against my building philosophy. Also there will be more places for potential leaks or hose failure.
Thanks for the "heads-up" reminder on releasing the brake after all is secure and tied down on the ramp. That item will go on my post-shutdown checklist.
As far as accidentally landing with the parking brake "ON" (not a good idea), I was thinking of a "T" handle in the center top of the instrument panel, near throttle or the lower left side panel hitting my knee when "engaged" so you can't miss the position of said handle. In addition, a micro switch at the valve body lever with red blinking LED light on the instrument panel near the handle to advise of a "BRAKE ENGAGED" status.
Oh, yeah, Wayne. I am not married, but I asked my ground crew, the "Swedish Bikini Team", about holding the airplane while I chalk the tires. They just told me that they don't do ramp chores. :)
Thanks again!
Over-and-out . . .
Terry Dazey
Rebel 662
Group:
Terry Dazey
R662
Tim Hickey
Post by Tim Hickey » Sun Feb 19, 2012 8:11 pm
I should have jumped in here sooner, but I just remembered the following:
Cessna uses (on some models) a small tab that fits over the shaft of the
brake cylinder rod and that serves as the parking brake. To activate you
apply the brakes, then pull a string, and the tab lifts up and engages and
locks the brake cylinder shaft. It prevents the shaft from withdrawing from
the brake cylinder. To release, you apply the brakes, and the tab falls, and
then the brake can release. The total added weight is very small. Can it be
made to work on the Murphy? I don't know, but if any body wants a picture, I
will crawl under the panel of my Zenith and take one.
This will be cheaper than a valve, and lots lighter.
Tim Hickey
R808
WALTER KLATT
Post by WALTER KLATT » Sun Feb 19, 2012 8:11 pm
In all my flying so far, can't say that I have ever really needed a parking brake (except on water, many times...). Closest I came to that was a few years ago, on a refuel stop in Hana Alberta, where the wind was blowing like crazy as I was trying to pull up to the fuel pump. I had to park somewhat sideways, so the wind wasn't pushing it backwards on me as I was getting out. Then I had to find some chocks quickly, and put the locks into my amphib front gear before they went down on me. Anyway, did manage OK, and that really was a worse case scenario.
Anyway, Terry, good to see that you are working on your Rebel again. Instead of inventing more work for yourself, get it finished... Or is that Bikini team sidetracking you too much...
Date: Thursday, January 15, 2009 1:45 pm
chores. :)
Thanks again!
Over-and-out . . .
Terry Dazey
Rebel 662
locked on a hot
or lines IMHO.
Group:
three years ago.
installed
Terry Dazey
R662
snowyrvr@mtaonline.net
Post by snowyrvr@mtaonline.net » Sun Feb 19, 2012 8:11 pm
Hey Walter,
Are you aware of any other Rebels flying with the 360? Craig walls
Original Message:
Date: Thu, 15 Jan 2009 14:14:59 -0800
chores. :)
Thanks again!
Over-and-out . . .
Terry Dazey
Rebel 662
locked on a hot
or lines IMHO.
Group:
three years ago.
installed
Terry Dazey
R662
myhosting.com - Premium Microsoft
Post by Mike Kimball » Sun Feb 19, 2012 8:11 pm
Landing with the parking brake on??? Wouldn't you have to take off with it
on to get in that situation? Surely you wouldn't accidentally set the
parking brake in flight. Of course, I know a guy who ended up up-side down
in a field because his young son decided to play with the fuel shutoff while
he wasn't looking. Of course, the kid was unharmed but the pilot was
severely injured.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Terry
Dazey
Sent: Thursday, January 15, 2009 12:45 PM
there.
checklist.
Thanks again!
Over-and-out . . .
Terry Dazey
Rebel 662
Group:
ago.
Terry Dazey
R662
I agree. The only time I have ever needed a parking brake is when I was
training for my CFI. I was flying a 1968 Piper Arrow and it didn't have
brakes on the passenger side so I just used the parking brake when needed to
make an exit or slow down while taxiing.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of WALTER
KLATT
Sent: Thursday, January 15, 2009 1:15 PM
chores. :)
Thanks again!
Over-and-out . . .
Terry Dazey
Rebel 662
locked on a hot
or lines IMHO.
Group:
three years ago.
installed
Terry Dazey
R662
kpierson
Post by kpierson » Sun Feb 19, 2012 8:11 pm
If using the Cleveland master cylnder-parking brake(Cessna)
such as suggested by"Tim" one must be careful to get the
linkage just right. I have this type of parking brake on my Meranda
and on one of the first taxi tests I applied left rudder and the
brake locked up, fortunately I was going slow so nothing
happened, but it could have locked up in the air and I wouldn't
have known it. I disconected them and find that I don't need
them
Keith P. R318
On 1/15/2009 1:05 PM, tjhickey@iowatelecom.net wrote to rebel-builders:
-> I should have jumped in here sooner, but I just remembered the following:
-> Cessna uses (on some models) a small tab that fits over the shaft of the
-> brake cylinder rod and that serves as the parking brake. To activate you
-> apply the brakes, then pull a string, and the tab lifts up and engages and
-> locks the brake cylinder shaft. It prevents the shaft from withdrawing from
-> the brake cylinder. To release, you apply the brakes, and the tab falls,
-> then the brake can release. The total added weight is very small. Can it
be
-> made to work on the Murphy? I don't know, but if any body wants a
picture, I
-> will crawl under the panel of my Zenith and take one.
-> This will be cheaper than a valve, and lots lighter.
-> Tim Hickey
-> R808
Post by Drew Dalgleish » Sun Feb 19, 2012 8:11 pm
Better get over that heads down habit before you're floating on a lake ;-)
