Chrome plated. The tire says 4 ply good for 300 lbs at 30psi. It shows
$16. in the large catalog which is odd because they were on sale a
couple of weeks ago for $4. Your regular $6.99 makes sense. Yes it fit
in the original MAM tailwheel forks. I ran a small grindstone on a
dremel through the 6202-4 bearing to open up the hole about 2 thou to
fit the axle easier and also bolted an insert into the wheel hub to
prevent the bearing outer races from moving into the hub. A spacer on
each side of the wheel to fill the space between the fork and the wheel
to lock the bearings into the wheel. Hope it stands up OK. Nice not to
have to clean up the grease that always splattered out of the original
wheel. I'd guess almost 2 lbs lighter than the solid rubber wheel.
Ron Shannon wrote:
If it's their #8064768, at only $6.99 ea., we could afford to run through a
couple of them each year. Wow. Looking forward to your 6 mo.
wear/maintenance report.
On Sun, Aug 10, 2008 at 5:23 PM, Ron Shannon <rshannon@cruzcom.com> wrote:
Ken,
Very interesting about the wheel. Can you give us a little more detail? Are
you still using the std. MAM fork? How about a part # or URL for the wheel?
Was this one of Princess Auto's pneumatic caster wheels?
Thanks.
On Sun, Aug 10, 2008 at 1:42 PM, Ken <klehman@albedo.net> wrote:
Also replaced the solid MAM tailwheel with a 2"x6" pneumatic wheel from
Princess Auto. I replaced the junk bearings with 6202-8 2RS permanently
lubed and sealed bearings which increased the expenditure by $10.
