hi all
does no body know a k & n part number to replace the reel stock foam filter
mike#007
air filters
air filters
I do indeed have a K&N on our Elite. It is mounted in a Van's O-360 air intake box. It was used because I have had good experience with K&N's on motorcycles and trucks. As a big plus, the Van's airbox filters all the air including carb heat air. The filter is a large round unit and should offer much less restriction than stock.
Now the bad news. The Van's airbox will require a "bump" on the left side of the speed cowl for clearance as well as some creativity to mate it to the square MAM air intake area. Our solution will be to graft a Van's air intake onto the bottom of the speed cowl for clearance. It will add a larger and better shaped hot air exit as well. Probably will add at least 50 knots of airspeed in addition to the extra build hours.
Steve Halvorsen
Air Filters
Can anyone advise me on what they are using for an air filter on a Moose with the M-14P engine?? ?
Have MAM's cowl.
Have to install one on and and need some help.
Steve H
Moose 213
Have MAM's cowl.
Steve H
Moose 213
