[rebel-builders] Rebel brakes
Post by Drew Dalgleish » Sun Feb 19, 2012 7:10 pm
Hi Dave I ate too much a month ago at the proper time for thanksgiving :)
The murphy resevoir is a blow moulded POS that you're better off not owning
just fabricate your own something with about a pint capacity. By slave
cylinders I assume you mean wheel cylinders and not toe brake ( master )
cylinders. Either way I think with kit 009 you have Matco parts available
from Murphy or Matco.
At 09:41 PM 11/25/2007 -0500, you wrote:
Hi all: Hope you all didn't eat to much this week!
Guess I need to get to it.
In my kit 009 I'm missing the brake slave cylinders and the reservoir for
the brakes, can anyone tell me what I should look for? and where I might
find them? or maybe get from Murphy? Also what about dual brakes? what do I
need for this option?
Progress on 009 is now at drilling the FUS 5's for the landing gear bolts
for the spring gear?? Scared to drill!! Need to get it correct to say the
least. Have been moving along and now getting ready to start laying out the
controls for as much as I have done.
Is there any comments about instruments? TSO-D or NON TSO-D Does it really
matter in EXP?
Thanks to all.
Dave T.
Rebel 009 here in cold Michigan!
Your smile counts. The more smiles you share, the more we donate.
Post by Mike Kimball » Sun Feb 19, 2012 7:10 pm
Are the brake cylinders the same in the Rebel and Super Rebel? I have two
brake cylinders for the SR that I don't need.
044SR
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of David
L. Tuck
Sent: Sunday, November 25, 2007 5:41 PM
Subject: [rebel-builders] Rebel brakes
matter in EXP?
Thanks to all.
Dave T.
I should say I have master cylinders that mount on the rudder pedals.
Kimball
Sent: Sunday, November 25, 2007 7:41 PM
Subject: RE: [rebel-builders] Rebel brakes
044SR
L. Tuck
matter in EXP?
Thanks to all.
Dave T.
Robert & Olga Johnson
Post by Robert & Olga Johnson » Sun Feb 19, 2012 7:10 pm
Having done both I can safely say "YES" they are the same mike. Bob J (the
brake pedal cylinders of course)
Sent: Sunday, November 25, 2007 11:40 PM
Richard Wampach
Post by Richard Wampach » Sun Feb 19, 2012 7:10 pm
Dave;
Aircraft Spruce carries the Matco brake master cylinders on page 243.
1-877-477-7823
MC-4 external reservoir, $74.95 Spruce pn 06-11000
MC-5 built in reservoir, $81.75 Spruce pn 06-11150
They also carry most of the systems for production aircraft.
Dick Wampach SR-108
David L. Tuck
Sent: Sunday, November 25, 2007 6:41 PM
for the brakes, can anyone tell me what I should look for? and where I
might find them? or maybe get from Murphy? Also what about dual brakes?
what do I need for this option?
bolts for the spring gear?? Scared to drill!! Need to get it correct to
say the least. Have been moving along and now getting ready to start
laying out the controls for as much as I have done.
really matter in EXP?
Thanks to all.
Dave T.
Post by Ken » Sun Feb 19, 2012 7:10 pm
As Drew mentioned, 119R shipped at 1500 lb. gross and came with Matco
cylinders and brakes which were very different than the JDM wheels and
brakes. The later developed JDM uses the aluminum axles that are about
1.5" diameter and cast aluminum wheels. The Matco's were stamped
aluminum wheels with 3/4" steel axles. Several years ago MAM gave me a
good credit for the Matco's when I upgraded to JDM.
Unlike most folks I like the plastic reservoir from MAM beccause it is
transparent and I can see the fluid level. OTOH I like master cylinders
that have an integral reservoir even more and they save space on the
firewall.
I've mentioned these before, but I'll restate how happy I am with the tiny
little ACS A-600 reservoirs that mount right on the master cylinders. About
$12 a piece. No fluid lines from a remote mounted reservoir.
044SR
Sent: Monday, November 26, 2007 4:31 PM
Subject: Re: [rebel-builders] Rebel brakes
firewall.
