corrosion-X? Do you use a long piece of tube, or what? I will probably use
soem kind of spray in protection in the wings as well, because I plan to be
in salt water. I am being pretty thorough about priming the belly and aft
fuselage/tail feathers, but in the wings I just did the standard priming of
the joints and rivets.
Subject: Re: [rebel-builders] Drain Holes
Date: Sun, 23 Apr 2006 11:38:07 -0400
Nope - it never occurred to me that water could sit in the wing trapped
by the stringers...
Haven't heard that one come up here before even though drain holes in
the stringers for letting fuel through has been mentioned a few times.
Too late as it is painted (unless the inspector balks). Oh well - I
think the top is well sealed and I did spray corrosion-X into the wings
last week.
Jesse Jenks wrote:
(justThe planes I fly at work have many drain holes that are done that wayaluminuma hole that had a drill bit or something stuck in it and bent toward the
tail). There are also other clever little drains made from machinedstillscattered around, but I don't know where you could get them. If theywaterlet me carry my Leatherman through security I could get some off.
Ken,
Did you put drains in the wings too, or just the belly? I was thinkingruncould get trapped against the outboard side of the tank rib, between the
stringers. In the leading edge and at the rear spar it should be able towaterdown to the root and out.
Date: Fri, 21 Apr 2006 17:26:40 -0400
Hi Alvin
I put a 1/8" hole ahead of every bulkhead to drain condensation and any
rain accumulation. Cesna's collect water so I suspect these will too.
I've also heard that there are a few inspectors around these parts that
insist on them. Never seen it done but one could always glue plastic
seaplane vents (as used on fabric flaperons) on the exterior if you were
worried about extensive operation in saltwater. Or maybe stick a drill
bit in the hole and bend the skin rearward a bit to make a mini scoop...
Alvin and Glenys Adams wrote:
so do you just drill a hole or is there a device i can ues that will let
water out but not spray in.If you land in salt water i would thinksomewould go in ,evaporate & leave salt residue inside the drain hole.Needadvice:
