a hand in there, though, even from the left side. Will
probably go down to the hangar tomorrow, so will at the
least see what might be possible.
https://www.dcsol.com/public/code/html-subscribe.wcx-----Original Message-----
Sent: Saturday, October 11, 2003 3:17 PM
Subject: Re: baffles
Maybe you can temporarily duct tape a hunk
of carboard, or similar, down the
center and then reach in through the larger
side to put some duct tape
between the cardboard and the cowl top and
go for a ride. See if it helps
and then bother to build the real thing if
it does!??!
Sent: Saturday, October 11, 2003 6:06 PM
Subject: RE: baffles
is closer toOK, I get it now. Never heard of that one, though.
The concern on mine might be that the right side
opening is tighter because the #1 cylinderindependently, mythe front, and that is also the side where my oil
cooler is. So if the sides then workright side, whichleft side would get more air than thefrom the leftis where my hot #3 cylinder is. With it open in the
middle, I was counting on some of the airoil cooler wasalso making it over to the right. If myis somethingon the left, I could see this being worth a try.
Interesting theory though, and maybe thiscurves on the topfor Bruce G to try and let us know how it works.
Sent: Saturday, October 11, 2003 2:04 PM
Drew would be talking about a straight piece
from your front baffle back to
the accessory case, bolted on using a couple
of top case bolts down the
center, with baffle seal along the top. This
keeps air from mixing from side
to side. My UTVA's have this down the center
of the GSO-480's.
Happy "Gobble Gobble" Canadians,
Sent: Saturday, October 11, 2003 3:31 PM
front to back plenum? For me cowl. The and I think youhttps://www.dcsol.com/public/code/html-subscribe.wcxbeyond my metal temps, as the right baffle. keep the temps with my #3 CHT*--------------------------------------------
-----------------------------*To unsubscribe from this list go to:
*------------------------------------------------------https://rebel:builder@www.dcsol.com/default.htmArchives located atmike.davis@dcsol.comTo contact the list admin, e-mail
mike.davis@dcsol.com-------------------*
Archives located at
https://rebel:builder@www.dcsol.com/default.htmTo unsubscribe from this list go to:
Archives located at
Archives located at
