Hi There All:
Got my cowling kit from MAM. They incorporated the instructions with the
packing slip.
1) 4'x8' .020 skin
2) 2 - 6' hinges
3) 3 hinge backing plates 3" x 3/4"
Makes you want to get right to it, if I only knew where to start.
Like alot of other things, just look at it long enough and you'll get the
idea.(search the archives)
Good Luck
Murray Cherkas
instructions
instructions
Hi Murray !
I have seen a full set of instructions for mounting the
nose bowl & fitting the cowl - can't remember where, though ....
Is there a section in the manual ??? If you don't have one, it
might be worth a call to Tech Support, because it DOES exist !
One thought - order more hinge !! If you want a decent
cowl, run a hinge above and below the horizontal channels on
the sides, AND on the top & bottom channels. This will allow
you to pull 2 pins on each side, and swing the doors up & down
on both sides, for complete access !! (See photos of Wayne's
in the archives).
Have fun !!
....bobp
----------------------------orig.-----------------------------------
in the archives).
Have fun !!
....bobp
Hi There All:
packing slip.
1) 4'x8' .020 skin
2) 2 - 6' hinges
Good Luck
Murray Cherkas
instructions
I'll second that! There is an instruction guide from 1993 available for the
nose bowl and alum door cowling. Vague but it puts you on track and like Bob
says check out the achives of pics I'm pretty sure that I posted of the four
door set up. I'll make sure they are there and if not add some more.
Sent: Thursday, April 03, 2003 11:21 PM
Subject: Re: instructions
*-------------------------------------------------------------------------*Hi Murray !
in the archives).
Have fun !!
....bobp
At 08:55 PM 4/3/03 -0800, you wrote:*-------------------------------------------------------------------------*Hi There All:
packing slip.
1) 4'x8' .020 skin
2) 2 - 6' hinges
Good Luck
Murray Cherkas
